Question about Whirlpool AWG5122 Front Load Washer
Washing machine stop half way in the wash and not draining the water out
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 27, 2011
Bosch washer E12 error. About 10 minutes into washing, the washer stop with half a tank of water in it. I'm able to run a drain and spin cycle afterward to drain the water out.
E12 mean washer take to long to fill check inlet valve an made sure the drain hose is at right high were the washer not siphon out ok
Dec 22, 2017 | Bosch Washing Machines
Will not shut off when plugge in...will still drain fine when I do plug in
How to Fix a Washing Machine Where the Water Won't Stop ...
homeguides.sfgate.com > Foreclosures > Other Foreclosures
1. Turn on the washing machine, and allow it to fill half full of water. ... Turn theshutoff valves on the cold and hot water supply lines clockwise to run off the water running to the machine. ... Remove it and all wiring connected to the terminals.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - When trying to find the the fault Please bear in. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay before looking any further. ... Washing machine will not drain or is noisy on drain. Generally .... As the appliance goes into to rinse it starts filling, then does not stop.
Jan 26, 2016 | Washing Machines
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
My washing machine has two flashing lights and it want drain the water it just stops half way through i think my water pump is broken
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesn't drain then you have a blockage anywhere from the drum outlet into the pump to the water pipe if it does drian then take the pump apart and check it turns freely
Jun 04, 2011 | Washing Machines
I have whirlpool washing machine AWZ475, after starting it take water in & at the same time ejecting too, and stops warking.
Sounds like your water is being siphoned out as its going in. Check your drain pie and make sure it rises over half way up the machine before it goes into the drain. Hope this helps
Feb 28, 2011 | Whirlpool Washing Machines
Water is continuously draining from my samsung washing machine . due to this unable to keep washing the clothes .why the problem come & what is the remedial measure to rectify?
Possible that the drain value is half blocked and so is not able to block the water in the tub. Remove the connection to the valve and check if this drains , if so it is confirmed. Remove, clean the dirt and reset. If the leak stays then the valve is faulty.
Also it can be due to partial voltage to the drain valve to keep it open which means that the program controller is faulty. This is confirmed when the drain stops as the connection to valve is taken off.
Jan 13, 2011 | Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine got to the spin cycle but didn't drain water
prolly cuz you didnt check your pockets first and either change or a set of keys fell out
Aug 15, 2009 | Washing Machines
Whirlpool AWG5122 Front Load Washer Logo
71 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
