Question about Neff 24 in. S5456 Built-in Dishwasher
Neff S5456X2GB/40, around 9 years old. on Auto wash, it appears to stick with what sounds like the pump running endlessly, with either 30 minutes showing, or 1 minute showing on display, but with soapy wet dishes, and a variable amount of water above the base, or in the filters. After a reset it will then empty the base normally. A rinse cycle also works normally to end of cycle - there is about 1 inch of water in the bottom of the base when the filters are taken out, I don't know if that is normal but it always seems to have a little water in the bottom when I clean the filters. I've checked the pump impeller under the white cover - there is nothing stuck there, it looks in perfect nick and turns freely. I've checked the sink end of the drain hose - nothing stuck there, and the drain is working just fine. It is plumbed in via a water softener so uses no salt. Any ideas about what to look at next? Thanks
  • drpetejohnso Mar 27, 2011
    Just to add - I've taken off the kick plate and steel cover - there is no water in the anti-flood tray - it's bone dry in there. What I guess is a vertical pushrod to activate the antiflood switch on the LHS moves freely - you can hear it click a microswitch.
  • 883 Answers
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Posted on May 26, 2007
IFIXALL
  • 868 Answers
SOURCE: Tablet salt
No unless you can find that tests were made and confirm that it is safe .
Posted on May 23, 2008
IFIXALL
  • 868 Answers
SOURCE: dishwasher - water softener not working
Make sure your water temperature is at least 120 degrees .Make sure your heater element is working and last of all ,Rinse Aid is the 2nd most important after water temp.
Posted on May 26, 2008
  • 3247 Answers
SOURCE: our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Posted on Jun 05, 2010
murdozzz
  • 41 Answers
SOURCE: Hi. Just bought a Blomberg
you will find the correct type of salt on the same isle as the detergent in the supermarket.
Regards
Ian
Posted on Apr 20, 2011
V4380X0GB/13
Try Googling (Neff)(V4380X0GB/13)(manual) without parens or contact Neff directly to request the manual.
Jun 07, 2017 | Neff Washing Machines
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Jan 01, 2014 | Neff Dishwashers
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
I have a Neff integrated washing machine, approx 9 years old. It is still taking in and draining water, although nothing else seems to be happening. The drum is not being moved (although I can move it...
A couple of possibilities here.
The drum belt could have off, or the motor is not working, possibly due to worn brushes in the motor.
Either way, it means the washer has to come out of the cabinet for you to check these things.
Please rate my solution .
Thankyou.
Jan 13, 2010 | Neff Washing Machines
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Jan 18, 2009 | Neff W5340X0 Washer
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
NEFF S5456 DISHWASHER
Have you tried it on a different program? I have nearly always used the AUTO program - however i have used the 50 degree program 3 times now and it completes the (much longer) wash without sticking on one minute. Will try it on auto again to see what happens. I found it useful to turn the end-of-wash buzzer on (to loud) to remind me when (if) it completes the program.
Sep 30, 2007 | Neff 24 in. S5456 Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
102 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
