Question about StarTech.com 35IN ESATA USB 20 TO IDE SATAENCLEXTERNAL HARD DRIVE ENCLOSURE (UNI3510U2E) IDE EIDE Serial ATA USB USB 20 eSATA External Drive Case
Device is not showing up in My computer - StarTech.com 35IN ESATA USB 20 TO IDE SATAENCLEXTERNAL HARD DRIVE ENCLOSURE (UNI3510U2E) IDE EIDE Serial ATA USB USB 20 eSATA External Drive Case
My computer didint show the device
If your computer is not showing the device, means it doesn't recognizes the it exists. Check connection of your device to computer and check if your device is powered on. By the way you never said what is ths deice troubling you.
Nov 16, 2014 | Computers & Internet
Machspeed Eclipse 180v 4GB not showing all files
The problem is that you might have unplugged your device, before all of your songs could sync onto your device. Try plugging your device back up to your computer and sync the songs on there that isnt already on your device.
Jan 23, 2013 | Machspeed Eclipse 180RD 4GB MP4
I have a maxtor 5000LE the device shows under
Could be that the control board inside the device is going bad. Have you tried other cables to connect to your computer?
If that fails, then I'd suggest removing the drive from it's enclosure and using an adapter to connect the drive directly to your PC as an external device. I found one on eBay, years ago, for about $13USD.
Oct 25, 2017 | Maxtor Personal Storage 5000XT (S01J250)...
Will not show up on the my computer screen but device works right
You could have changed the OS that the device was running on. Try unplugging device, then turning off computer and plugging it back in. Then restarting computer, that should work.
May 12, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
The device does not show under My Computer when plugged in
You will have to go to the Manufacturers Website and Download Updated Drivers for your PC. That should take care of the Problem.
Jan 08, 2009 | SanDisk Sansa e250 MP3 Player
Computer Freezes
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
SanDisk SDMX1 MP3 unable to access drive.
do one thing u r soft ware totaly adjuest and formate t u problem will be clear its not working the usb be charge set change it ofter it work ok
Feb 07, 2008 | SanDisk SDMX1 MP3 Player
Can not delete songs
If its not showing up, try changing the mode on the device.
Settings>Mode or USB>Change to the other mode.
Connect to your PC. If it shows up, format the device.
To format in My Computer>Device (m230)>Right Click and select format.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa m230 MP3 Player
StarTech.com 35IN ESATA USB 20 TO IDE SATAENCLEXTERNAL HARD DRIVE ENCLOSURE (UNI3510U2E) IDE  EIDE Serial ATA USB USB 20 eSATA External Drive Case Logo
23 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
