Question about Lexmark P4350 All-In-One InkJet Printer
Ink levels of refilled cartridges
Are lexmark 4350 cartridges resettable after a home refill.
  • reandbe Oct 28, 2008
    Refilled cartridge with no problems but printer tells me cartridge is empty and and must be replaced....help!!
  • 300 Answers
Refilled cartridges usually do not show the correct ink levels. As far as Im aware there is no way to adjust that readout on those cartridges.
Thanks
Posted on Aug 09, 2008
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
How do I reset a refilled printer cartridge for a Lexmark X4650?
They are not resettable. This is one of the downsides to using refilled cartridges for this style cartridge. You should be able to tell the printer to ignore the ink levels and just print until it runs out of ink.
Jun 09, 2010 | Lexmark X4690 Wireless InkJet Printer
How to refill an Epson printer Cartridge T0881 Black ink, have the set although instruction do not include this model.
To refill epson cartridges, you will need a resetter of the cartridge to restore the ink level back to full content.
You can buy a spongeless cartridges with an autoreset chips for your printer so that you will not need the ink cartridge resetter anymore since it will auto reset. This is my suggestion since spongeless cartridges are easy to refill than the genuine cartridges. Hope you can find in your area. If not, you can go to the nearest ink refilling center in your area and you can let them teach you if they will. Hope it would help.
Dec 18, 2009 | Epson Stylus NX400 InkJet Printer
How do i go about refilling epson T5591/2/3/4/5/6
Before you can have unlimited refilling you must need this devices:
Option 1: The chip resetter which you will need to manually reset the cartridge before refilling to enable the printer to recognize a new cartridge.
Heres the link where you can buy the resetter:
http://cgi.ebay.ph/CHIP-RESETTER-For-EPSON-T5591-T077120-T078120-T0791-INK_W0QQitemZ290276640766QQcmdZViewItemQQptZBI_Toner?hash=item4395d607fe
Option 2: You a new set of empty cartridges with autoreset chips in it. No manual resetting needed, what you need is to refill and monitor the ink level.
Explanation: When the printer detected that the cartridge is empty, the printer sends data to the cartridges and the cartridge understand what the printer says, then the cartridge automatic chip resetter will re trigger the logic circuit built in into it to reset into full ink level.
Here is the link of the autoreset chip what Im taking about:
http://www.made-in-china.com/image/2f0j00wCVtjAmMPlchM/Refill-Cartridge-with-Auto-Reset-Chip-Canon-520-501-.jpg
Oct 21, 2009 | Office Equipment & Supplies
Lexmark X3650 all-in-one Printer, have refilled colour cartridge with inkjet refill kit but still indicates low-ink level, and will not function. Do I need a resetter?
Go to all in one program
at the top left click on Maintain\Troubleshoot
Right window click on Device Status And Ink Levels
that will open a new window
Click on The button that looks like 4 different colored ink drops
Click on Install a new print cartridge
Click on Next
Now you should be in Select The cartridge installed
Open lower drop down window and click on No its new
Follow the prompts from there or click OK
This should fix the problem.
Oct 21, 2009 | Lexmark X3650 Printer
Refilled Lexmark X4530. Printer continues to show
It is highly unlikely to be a driver issue.
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
If you are lucky you should be able to find either a resetter-cli8-pgi5.html" rel=nofollow target=_blank>chip resetter around on the internet
OR
Even better empty cartridges that never need to be reset.
That's the option I like I realise these are not for your specific printer but there are others listed on both those sites as well
Aug 18, 2009 | Lexmark X4530 InkJet Printer
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark x5470 all in one printer-low ink level
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Mar 06, 2008 | Lexmark X3550 All-In-One Printer
Resett ink levels
are the cartridges resettable after a refill ?
Jan 02, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
346 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
