Question about Car Audio & Video
My CD player doesnt work, i get the instruction to load disc in my digital disply but when i put a disc in any of the 5 slots, the disc doesnt spin and the player doesnt seem to grab my disc and pull it into place??
    Scholar:
  • 146 Answers
Is there a button an player that says "load" - if so you need to push that before inserting discs
if you dont have that button you have a bad sensor that is not "seeing" when you put a disc in and telling the player to grab the disc and play it
if it is bad sensor you can try opening unit and looking for a sensor (probably an optical one and try cleaning it with a qtip and rubbing alcohol but that might not work and the sensor might have to be replaced
good luck!!
Posted on Mar 27, 2011
TECHNICS SL HD81 5 CD MULTICHANGER. The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on th
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
Nov 04, 2012 | Technics Audio Players & Recorders
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
It Loads but doesnt spin and said "no disc."
Try cleaning the lens with a DVD Disc Cleaner or Methylated Spirit and a Q-tip, rub the lens slowly in a clockwise motion, leave to dry and put in a DVD, if it doesnt work try a CD but make sure they dont have any scratches or dust on them, if a CD works ( or not ) then your lens is knackered.
jon
Aug 12, 2009 | Polaroid Portable DVD Player PDM-0822BD
Mintek portable dvd player
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 08, 2009 | Mintek MDP-1815 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
No disc loaded warning message
First check the optical pick up is working or not or change with a new one.
this part is availble with JVC service provider in your area.
Jan 10, 2008 | JVC 5 Disc Progressive Scan DVD/CD Shelf...
Bad disc
I have the same problem with some of the Discs I have burned. Most people say the power supply, but I have 2 of these units so I swapped the power supply to see if that was it. The problem stayed in the one machine, ruling out the power supply.
Aug 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
