Question about Telex 4-52NH SpinWise CD Duplicator, Four Drive 52X CD Tower without Hard Drive (452NH, 4 52NH) (452NH) Burner
I can not copy cd+g how do I set it to do that,thank you,
  • 391 Answers
Hello you will need to download the software below to copy this sort of format
cdg karaoke
Posted on Mar 27, 2011
I want to know how to make copies of DVDs and audio CDs using acer aspire 5742 laptop
Download and install Nero Burning Rom program, open it, set in the up window the option CD/DVD, get to preferite, copy CD or copy DVD option, depends by what you need, set the speed 4x for DVD or 8x for CD for have a good copy quality, insert the original disk, it will copy it, then insert the new disk to burn.
May 16, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
How can i scan 1 cd and burn 20 50 cd's without having to scan everytime before I burn.
Set your number of copies to 50. The software will remember how many units it has done.
Mar 23, 2011 | Samsung Computers & Internet
I bought my acer aspirem5810 on 1/1/2010 and i used the shrink to have more partition and then when i wanted to creat the factory default disc i have an error which''the hard drive configuration is not set...
Hi, unfortunately, when you changed the formatting to (Shrink); this changes the Original settings from the Factory settings. You may need to make a copy using the factory / default setting firsts; then change the settings to shrink formatting, making a separate copy to CD. Thanks paul7of9
Jan 03, 2010 | Computers & Internet
Dell Inspiron 1420 Factory Setting Recovery
back up all your files first because everything will be wiped out.
Turn on machine, Put the recovery cd on the cd rom drive, before it boots to windows hit the F1 to go into bios, on the startup set the cd rom the primary to boot machine on cd then follow the instructions from there..
Jun 30, 2009 | Dell Inspiron 1501 Notebook
I need ASUS P5AD2-E Premium set-up CD
I would be happy to send you a copy if thats ok.
Oct 27, 2008 | Computers & Internet
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
Prepares download copies but has problem at final stage of copying to disc
It might be because your cd is not good at the end that's why it fails at the final stage to copy the cd..try using the nero software and when it open use copy cd option and when it ask for burning select image recorder......so when it copies the cd you will get information whether cd will be get copy or not..,
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 26, 2008 | Computers & Internet
Transfering mail setup from Windows xp to a windos vista machine with EasySuite
I'm not 100% sure about vista because I hate it but I can help you copy all of your outlook express data to a CD\DVD disk & your address book. Your network settings for express account is a phone call to your ISP.
If vista's explorer is set up like XP you should be able to copy your data into outlook express.
Open all these folders on you XP system.
User name\Application Data\Identities\{xxxxxxx}\Microsoft\Outlook Express
Copy the Outlook Express folder to your CD.
User name\Application Data\Microsoft\Address Book. Copy Address Book folder.
Making sure you have everything.
Open, User name\Local Settings\Application Data\Identities\{xxxxxxx}\Microsoft\Outlook Express
Compair the two Outlook Express folder files. CD will not allow copy of same named folder.
If Vista's lay out is the same as XP than copy Outlook Express folder to Vista.
Suggest you have your current ISP setting /account setup before copying to Vista
Let me know if this works for you!
Good Luck & Kind Regards.
Mar 21, 2008 | Computers & Internet
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
Can someone tell me how to set the stations? Thanks!
owners manual.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/128163985FH-P5000MP%20OPERATION%20MANUAL.pdf
Jun 05, 2007 | Pioneer FH-P5000MP CD / Cassette Player
Telex 4-52NH SpinWise CD Duplicator, Four Drive 52X CD Tower without Hard Drive (452NH, 4 52NH) (452NH) Burner Logo
93 people viewed this question
Top Telex Computers & Internet Experts
Longtime User
ray gallant
Tom Chichester
Are you a Telex Computer and Internet Expert? Answer questions, earn points and help others
