Question about Samsung CD-RW SW-212 Burner
Sir i have samsung cd rw drive i play mp3 cd some time after i change a new disk the drive give no responce i check in my computer but there is no drive show . i install new operating system but drive not show .rom tray go in side or out side . led light are bllinking when cpu start but RW Drive is disable pls give me advice what can i do .pls give me service center address
  • Samsung Master
  • 27,725 Answers
Make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 27, 2011
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
Aug 01, 2010 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
CD-RW Station can't read disks anymore
The easiest thing to do is to update the firmware on the drive. If that doesn't work, check to see if the drive is getting adequate power, which can be caused by new hardware being installed that is taking up more power than the power box can give.
Clean the plugs and ribbon leading to the computer with a quick burst of compressed air.
If that still doesn't work, the laser may be mis-alligned, or borken, and is much easier to replace the whole drive. (CD-RW burners are insane cheap with DVD-RW burner drives being out for a long time, and Blu-Ray burners just around the corner)
Dec 17, 2008 | EXP Computer EXP CD-RW Station CRW 2400U...
DVD-V2000
All those disc formats will work with what you are trying to do. Are there problems?
Nov 04, 2008 | Samsung DVD-V2000 DVD Player/VCR
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Samsung CD-RW SW-212 Burner Logo
60 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
