Question about Altec Lansing ADA995 Speaker
I have an older Altec Lansing system that was hooked up to a dell desktop - i am replacing the Dell wit an iMac - the speakers are a sub woofer plus 5 surrounding speakers the 5 are connected to the the sub woofer - the sub woofer is connected to the computer with a wire that is permanent on the woofer and has 3 connecters on the computer end - they are unmarked but color coded - yellow green and black - the iMac has a single connection - will one of the three do the job? which one?
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Sub Woofer to Sound Dock
Well if you are talking about the iM600 sounddock from Altec Lansing, the short answer is no. If you want better bass from an IPOD docking system you'll need to buy an expensive component from say Scandyna Dock or you could build one yourself. You would need an integrated amp or a complete system like the NAD C71. This would allow you to plug in a self-powered sub.
Dec 01, 2008 | Apple iPod classic MP3 Player
Speakers for Altec Lansing 5100 system on and off
this is due to small mismatch on ur dell desktop with speakers, so remove it and try again
Aug 16, 2008 | Altec Lansing 5100 Computer Speakers
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Altec Lansing ADA995 Speaker Logo
85 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
