Question about Bernina Artista 170
My needle won't move even with hand wheel. Feed dogs move. Bobbin turns. Bobbin winder is off. Did same thing last night then worked when I turned it on this morning. Quit with 6 inches left of 12 yard ruffle.
    Scholar:
  • 89 Answers
You have a gumed up basting device, You can try to fix yourself but should be taken to a bernina teck for a fix. Take the end cap/head cap/ side panel/ needle bar panel off. It is one screw on the left side.
Remove neddle
Find the needle bar
On the needle bar there is a black small pice, it is round and has a little tab that stitcks off it.
Pull the needle down and push/pull/wiglle soft on the small black tab.
There is a small pin inside that should clip into a hole in the needle bar.
This should get your machine sewing again but the basting device realy should be cleaned and adjusted, should be around $45-100.
Hope this helps.
Posted on Mar 28, 2011
The machine turns on but I cant get it to work
Without more information, it is difficult to diagnose. Just a suggestion to check that the bobbin winder is not activated. Generally, when the bobbin winder is activated, it prevents the needle bar and feed dogs from operating.
May 09, 2017 | Sewing Machines
Hand piece is very tight to turn and unable to use the machine
Make sure to clean/remove all the lint, thread, dust, etc. that may have built up in the bobbin area, around the feed dogs, and under the needle plate. Sometimes gunk build-up will prevent the hand wheel from turning. Remove the bobbin & bobbin case from the machine and the needle and see if the hand wheel will turn. If not, then it may be time for service.
My hand wheel is hard to move and will not make complete turn unless...
https://answers.yahoo.com/question/index?qid=20100518074139AAeeykz
Help My Needle Hand Wheel are Stuck Sewing Machine Jammed
Apr 20, 2016 | Sewing Machines
Needle wont pick up bobbin thread
START WITH: SHARP NEEDLE (NEW), GOOD THREAD (NOT FUZZY-LONG STRANDS), ADJUST TENSION OF BOBBIN AND TOP.
1. Check the bobbin area and make sure the hook(pointed thing) and bobbin are all secure.
2. After you have adjusted the tension and reinstalled the bobbin: Extend three inches of thread from the bobbin.
3. After threading the top place the thread under the pressure foot and hold on to the thread. Turn the hand wheel towards you.
4. The needle has went under the throat plate (feed dogs plate) and begins to rise. You should feel the thread get caught and give a little resistance while you continue to turn the hand wheel.
5. The bobbin thread should come up with the needle thread.
6. If this hasn't taken place check to make sure the needle is inserted the right direction and totally pushed in. Retry again.
7. Look at your bobbin while turning the hand wheel. The needle thread should ride across the bobbin case and exit to the top of the machine again.
8. If these have not worked you will need to have your machine timed or the hook replaced.
ATTACHED IS A GUIDE FOR SETTING THE TENSION.
May 30, 2015 | White Sewing 2999 Mechanical Sewing...
How do I fix an error e6?
Start by trying to turn the wheel with the bobbin and the auto-thread cassette removed. Look inside to see if there is any thread caught anywhere both in the bobbin area and also in the complicated mechanism where the auto-thread cassette fits.
  • If it is still stiff, remove the needle plate, which also holds-down the cover over the bobbin carrier. (You may need to use a coin and a pair of pliers to undo the 2 screws as there is very limited vertical clearance at this point)
  • Remove the bobbin carrier, noting which way it fits. Thread and fluff can build up in this area.
  • Thread might have become wound round under the rotating component into which the bobbin carrier fits.
  • Put one drop of oil in the edge of the large screw in the centre of the rotating component and turn the wheel a few times. Put another drop of oil in the same place and continue to turn the wheel.
  • Look carefully with a small flashlight into the case and see if there is any fluff or thread bits caught in the feed dogs mechanism.
  • Put one drop of oil onto any joint between moving parts that you can see.
Now, if there is no improvement and you cannot see any threads caught, you need to see if there is anything wrapped round the bevel gear drive under the bobbin carrier rotating mechanism.
If you go to "How to fix Brother's CS-8060 bobbin auto winder to work?" thread on this forum there is a description of how to separate the 2 halves of the case. (I apologize for omitting to say about Large +Screw #6, located in the top of the case where the Auto-Thread cassette fits)
  • Splitting the case enables you to have a good look around under the mechanisms and check for any thread or fluff. Put one drop of oil on any moving joint.
  • Rotate the wheel, being careful to keep your fingers out of the way as you do so. Take careful note of the area below the bobbin mechanism, where there is a bevel gear that turns the drive through 90 degrees.
  • There is also an eccentric part that moves the feed dogs mechanism. Check there is nothing clogging-up this bit. You can use Lithium-based grease very sparingly to lube the cams and plastic/nylon components
  • Put one drop of oil onto the needle-shaft, above where it slides through the mounting. Turn the wheel a few times and put just one more drop of oil.
  • Look at the crank mechanism that drives the needle-shaft and apply one drop of oil on any moving joint or component.
  • While you are in this area check that all the bits that move do so freely, especially the little joints of the auto-thread.
  • Have a good look around the area of the bobbin winder, up by the wheel. - Has the bobbin winder drive rubber gone gooey? Is there anything caught up there?
Hopefully you may find what is causing the stiffness. It is not really likely that one of the shaft bearings is tight but you can put a little oil each side of the bearing and continue to turn the wheel to see if this frees-up any.
Take care to wipe any excess oil off, particularly where it might get on anything you sew.
Don't get oil on the drive belt and don't blow any fluff up into the motor area or, especially, the speed-sensor disk (which is a black thing with fine slots.
Assemble the components carefully. You might take a few cell-phone pictures to help remember how things go.
Feb 19, 2015 | Brother CS-80
Why won't my old manual singer sewing machine needle move?
1. Disengage the bobbin winder.That is done by moving the arm away from the center wheel. 2. Tighten the hand wheel. When you tighten you should have resistance like a jar has. If this doesn't then continue. 3. Loosen the small screw attached to the hand wheel center lug. Now, move the hand wheel into a position where it will tighten. 4. Go ahead and tighten the small screw. Now, it should move.
Nov 19, 2014 | Singer Sewing Machines
Singer 974 MY NEEDLE WOULDN'T MOVE WHEN I TURN THE HAND WHEEL AND MY HAND WHEEL WOOBLES. HOW CAN I FIX IT?
slacken the small stop screw and remove the centre free motion knob. the balance wheel should now be free to turn independent of the shaft. you will have exposed the friction washer. clean all surfaces and relocate the washer with the two locating lugs facing outwards into the two slots in the shaft and refit the knob and screw. if the screw bottoms on the friction washer remove knob and turn the friction through 180 degrees and try it again
Feb 21, 2014 | Sewing Machines
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Sewing Machines Logo
155 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
