Question about Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure in the line. Any ideas?
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Posted on Mar 27, 2011
  • Prem Mulberry Apr 13, 2011
    There is a service manual available athttp://steprightupmanuals.com/washing-ma...
How do i replace bearings on Maytag Neptune model MAH5500BWW?
Here a website for you with a video that will assist you in this repair.
Good Luck
Maytag Neptune Bearing Replacement How to Replace Neptune Tub Bearings
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 09, 2014 | Maytag Neptune Washing Machines
I have a Maytag Neptune Model #MAH5500BWW, and it leaks water only while it's filling. It's almost like it would rather fill my floor than the tub. When I start a spin only cycle to get the water...
Sounds like a leak either in the bottom, connector or water valve for your water inlet line. Visually finding the leak is your best bet, then you know what parts are to be replaced.
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Jan 25, 2010 | Maytag Washing Machines
Maytag Neptune MAH6700AWW overflows out the detergent tray opening while filling
water leaks out of the plastic box where you put the detergent/bleach/fabric softener, from the OUTSIDE of the box onto tub, drips down tub on to metal tray and into drawer. Anyone had this problem?
Nov 07, 2009 | Maytag Washing Machines
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dear rxpert. I have washer Maytag Neptune Model MAH5500BWW Model 67787785ZH. After, The washer completed the Work, that still have water inside of washer (I hand to turned the basket inside the washer I...
This is actually normal. It is normal to have water between the wash basket (stainless steel tub) and the outer wash tub (plastic). There shouldn't be a problem unless the water is excessive enough to pool inside the wash tub itself or overflow onto the floor. You will always find a small amount of residual water between the tubs. Don't waste your money on a service call unless you absolutely have to.
Apr 10, 2008 | Washing Machines
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
760 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
