Question about Whirlpool Washing Machines
Keeps saying F1 when trying to start - Whirlpool Washing Machines
  • john_cross Mar 27, 2011
    (I have posted this as clarification rather that solution in case it isn't- you posting will remain 'live'!)
    Sorry, I do not have the decode for Whirlpool 'F1' BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. It's worth a try!
    So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
    Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
    REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
    Hope the filter is the problem and good luck!
    John C
  • 822 Answers
If the control has turned the water valves on and after 8 minutes the flow meter has detected water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display. If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves Check inlet valve operation If there is water in the unit: Check Drain pump operation Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch Check there is not a siphon problem Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) Check all hoses for possible leaks Check pressure switch operation Check flow meter operation Check CCU operation
cheers
Posted on Mar 27, 2011
Smart failure predicted on hard disk 0: samsung hm321hi - (PM) Says press f1 to continue.. But nothing happens after i press F1.. Hard reset already tried.. When i turn the laptop on, it says "system...
Have you tried starting in safe mode or connecting the hard drive to another computer as a 2nd drive and accessing it that way and trying to repair and virus check
Dec 01, 2017 | Computers & Internet
My oven wont stop beeping at me and showing F1. It keeps saying something about the self-cleaning. I've tried unplugging it and pressing all the buttons. It stops for a couple seconds and then starts
It has an issue with the thermostat, a temporary solution for my oven was to restart the oven and it would work for a little bit.
Dec 09, 2012 | Ovens
My computer boots to the windows screen the it say f1 to try boot f2 for ulitity is ther anything i can do no boot disc
try this when you start your computer press f8 and keeps tapping it until it boots into the boot menu then select safe mode. then try system restore to a date before this happened. hope that helps let me know.
Jan 18, 2011 | Dell Dimension 3000 PC Desktop
Everytime my laptop opens its saying a SMART failure was detected in ur hard disk drive,click F1 to continue...do i really have to change my hdd or it can be fix..but if i check in device manager it says...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive or
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
good luck with this
Sep 15, 2010 | Hitachi Computers & Internet
I cant get into the BIOS from Portege 3500
Keep hitting escape while starting up. Message will say there is an error and hit F1. Hit F1 and you'll enter bios.
Apr 18, 2010 | Toshiba Portege 3505 Tablet PC
Washer keeps coming onf1
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. The cost of the part is around $119.46...
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Start up issues and screen problem
try a new start up disk or try pushing the F8 turning com. on keep pushin till sceen comes up with some solutions,
May 08, 2009 | Computers & Internet
Trying to reformat my PC but can't get into BIOS set up.
Hey,
Seems the screen is slow to start up, right after pressing the power button, keep tapping on f1 or f10 untill the bios screen or something else comes up. that will definitely get you into the bios and dont mind if the computer starts to beep, slow down a little and keep tapping.
Thanks,
Ekse
Aug 30, 2008 | Computers & Internet
Washing Machines Logo
27 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
