Question about Whirlpool GHW9300 Duet Washer
Constant alarm - Whirlpool GHW9300 Duet Washer
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside. It's worth a try!
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 27, 2011
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Constant sounds coming from my truck alarm
Pull fuses until it goes away. Also pull relays you could hae a bad relay
Jan 03, 2014 | 5704x 570.x 2-Way Security and Remote...
Trunk ajar alarm sounding constantly, even though trunk seems to be closed properly.
the sensor is part of the latch so that will have to be replaced to fix it. Although water has been known to seep into the latch through the key hole (bad gasket) and fixes itself when it drys out.
Dec 09, 2013 | Pontiac Solstice Cars & Trucks
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
How can i shut off my kidde carbon monoxide detector, it is a constant alarm unless you remove the battery completely
Try another hard whack. If that does not undo the initial damage, nada will and you have a nice paper weight.
Sep 01, 2017 | Kidde Nighthawk Combo Gas/co Detector
Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sliding door alarm sounds constantly
there must be a switch some where , around the door to shut it off when door shut
May 10, 2009 | Chevrolet Uplander LS Cars & Trucks
Jeep grand cherokee 2000 3.1 td alarm indicator light situated on dashboard
If this is an after market alarm it could have been turned off.
Jun 20, 2008 | 2000 Jeep Grand Cherokee
Washing Machines Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal De
