Question about Krups 287 SensoToast Deluxe 4-Slice Toaster
My Krups Sensotoast Deluxe just stopped working. Can you help me? I really don't want to throw it out because it's relatively new and I expected a product with this name to last a lot longer.
The printed circuit board is likely burned out. It's pretty sad really. This is a poorly designed toaster. Krups owes us new toasters in my opinion. Looks like a fire hazard too. If you are curious, you can remove the 4 philips head screws out of the bottom of the toaster, gently pry off the push down lever and the dial, and examine the board and connections. My Krups Sensotoast Deluxe just stopped working. - 8_25_2012_1_16_19_pm.jpg
Posted on Aug 25, 2012
2 Suggested Answers
SOURCE: Krups Sensotoast Deluxe -- Stopped
Did the same to me
The ceramic heater to wire connection broke off
not a prayer of fixing it
The heating elements are in a series circuit, so as goes one element, so goes both elements.
Posted on Dec 21, 2010
I'm looking for an error code meaning that appear on my krups coffee machine the error code is "code error 02"
You will probably get some proper help if you identify the exact model. I don't expect "error 2" to mean exactly the same on every model Krups have ever made, narrow it down a bit for us please.
Mar 22, 2017 | Krups Coffee Makers & Espresso Machines
Can the number wheel be replaced in a Casio 160 CR-B cash register? The till was bought in 2005
They don't sell parts for them. They just sell you a new printer. You have done well. These tiny cheap machines don't last a long time. They expect you to throw it in the bin and get a newer one now
Oct 14, 2011 | Casio Parts Cash Register PC Desktop
Krups Sensotoast Deluxe -- Stopped working!!! Checked outlet. Not the problem.
Did the same to me
Aug 06, 2010 | Krups SensoToast Deluxe 4-Slice Toaster
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
The toaster was turned upside down and now it will not heat. The carriage does stay down
Sfety switch needs reset. Open the bottom and look for a switch in the cord wires circuit.
Sep 07, 2009 | Krups 287 SensoToast Deluxe 4-Slice...
Krups toaster won't work.
I do not know the exact inner workings of this toaster, but I can suggest what the fault may be.
Many of the toasters use a separate high power section in the eating element for toasting. This part of the element could have gone defective. There is the possibility the computer board that directs the power for the higher temperature mode for toasting has failed.
The only reliable way to know is to try the computer board, element assembly, or the switches if the switches are on a separate module than the computer board.
Just to add... These toaster units usually have a thermo protection fuse. These fuses have a temperature rating. It would be in series with the element. This fuse may have failed. This is a common fault in many of these types of units. This type of fuse is rated in Degrees C or F, and not in Amps. it is a thermo fuse.
Apr 02, 2017 | Krups 287 SensoToast Deluxe 4-Slice...
Krups xp2070
In my case the problem was a faulty flow meter. I replaced the flow meter and the unit now works great! The microcontroller expects water flow information to deliver the right amount of liquid. If the unit is not getting flow information it will stop and start blinking.
Oct 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
GoGear 4GB SA3345
i have the same problem but am taking it further check out this link http://www.berr.gov.uk/consumers/fact-sheets/page38311.html
Jul 02, 2008 | Philips GoGear Flash MP3 Player
Problem with jaipan toaster
the release mechanism contains a bimetallic strip that snaps open when a certain amount of power goes through it based on the setting. When cold, it should trap the toast loading lever mechanism. If not, it may be broken or bent. Don't work on it with power applied
Nov 21, 2007 | Krups 288 SensoToast Compact 2-Slice...
Krups 287 SensoToast Deluxe 4-Slice Toaster Logo
317 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
