Question about Refrigerators
I have a bottom freezer Amana model br18v1c. The freezer evaporator core freezes to solid ice. What do you think could be wrong?
SOURCE: water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
Posted on Sep 03, 2007
  • 5 Answers
SOURCE: ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Posted on Apr 02, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
lojacksdad
  • 121 Answers
SOURCE: bottom freezer, ice cubes melting and refreezing.
defrost timer saying off to long
Posted on Apr 17, 2009
projdoc
  • 2237 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
The coils in the. Back of the freezer keep freezing up! I use a hair dryer to thaw...freezes up again...what is wrong
The problem could be in the draining of defrosted ice. The drain may be clogged thus allowing water to back up. Next I would check the fan and make sure it is running. The last thing if that doesn't help is get a refrig specialist to check out evaporator and compressor. Now consider this, if it is much older than 10-12 years old , you may want to replace it. His sometimes is the beginning of the end.
Feb 03, 2013 | Amana ABD2533DES Stainless Steel Bottom...
Freezer is cold but it is not freezing foods.
When it comes to refrigerators I always have a most likely to least likely formula to try to solve the reason of why the freezer or fresh food compartment is or is not cooling properly. So knowing that the cold air comes most times from the freezer compartment I would look to see if the fan inside that compartment may just be slowing down because it is possible there is frost building behind the freezer wall due to most likely defrost not taking place and creating a huge block of snow and ice blocking air circulation.. Ice will show on the outside wall of freezer also if possibly the defrost heater is burned out. There are so great testing tutoral'son the following links! So now having your model number that most people don't think about I will look to see just what type of defrost system your model has=> ABB1927DE EVAPORATOR AREA and Rollers location 16 in photo. That part is your models=> 67002135 Defrost Heater
Amana, ABB1927DE User Manual
Sometimes the 67003636 Evaporator Fan Motor goes bad but thawing is more severe when the evap. fan goes bad and may be tricky stopping and starting on its own before true-ly burning out=> 67003636 Evaporator Fan Motor
here is a Amana ABB1927DE Wiring Diagram=> HERE
67003426 Defrost Thermostat Hey I know there is a lot of material here so I will be here if you should have questions, Thanks, Sea Breeze
Jun 01, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer not cooling properly and iceing over
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism.
Here are some images that should be similar to your situation to help assist you and the principal is the same with either over-under or side by side refrigerstors, and let me know if you require any further assistance.
Oct 02, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Freezer is making frost, fridge side doesn;t seem cold enough however the vent near the meat and cheese drawer is frozen solid. what might be wrong
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is actually that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism. The defrost heater coils can easily be checked by dis-connecting them and using an ohm meter, and a high or an infinite reading would indicate a faulty heater coil, however most of the time they are easily identified as being bad just by looking at them.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
Sep 24, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Refregarator get defrost at the meant time, frezer working well.
The problem is most likely the defrost heater element(s) and/or the defrost timer. The defrost heater element(s) are located with the evaporator core behind the access panel inside of the freezer, and can be removed, tested with an ohm meter, (any reading other than infinity would most likely mean the heater element is functional) and replaced if necessary. The defrost timer can be located inside of the refrigerator, or outside of the refrigerator behind the front kick panel, or behind the rear access cover on the back of the refrigerator.
Usually if the evaporator core is freezing up and not allowing air to flow through the evaporator core, (necessary for the system to function properly) then the defrost timer is most likely working and the defrost heater element(s) would most likely be at fault.
Always place a towel on the bottom of the freezer and use a blow dryer to defrost the evaporator core and never use any sharp or hard objects to pick away the ice or the evaporator core can be damaged and the refrigerant will be leak from the system.
I have included some images to help assist you, and a new defrost heater element or defrost timer can be purchased from an appliance parts distributor.
Jul 17, 2010 | Amana ARB8057CSL Bottom Freezer...
When the door to the freezer is closed there is a vibration noise from the icemaker. When the door is opened, it is quiet. Also, the ice is not forming solid Thanks
Possibly there is a 2 part problem you are experiencing. 1)That vibration i dont think is the ice maker. It is your evaporator motor. 2)The fact that the icemaker is not forming the blocks nicely could be because the freezer setting could be set a little to low. The freezer temp. is what freezes the ice maker blocks. You may want to play it safe and do a 12 hour defrost which may be the reason why the vibration is heard.and reduced freezer temp.
Jun 05, 2010 | Amana ABB1927DE Bottom Freezer...
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 16, 2009 | Amana ABB1927DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Jul 15, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
