Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
    Top Expert:
  • 1,575 Answers
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Posted on Oct 06, 2011
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Cannon mx452 the error light wont go off
try to check if the is a pieace of paper remain the machine or check the seasor where you had to remove the paper
Oct 15, 2014 | Cannon Office Equipment & Supplies
My Canon PIXMA MP145 does not print although there is black ink and no error code. The paper comes out blank when print is selected. Same with photocopy mode.
This problem may be caused by another print cartridge that is empty. This is a ridiculous 'feature' that is apparently common among most printer manufacturers.
If you think this is your problem try the following:
When you select the print option in whatever program you are printing from click on the Preferences button.
-In preferences click the Borderless Printing option, then select Plain Paper as the paper type.
-Next select the Grayscale Printing option.
-Finally click the OK button on the preferences then in the print window click the Print button
NOTE: The above is describing the options for the Pixma IP4700, the terms may be different and there is a chance this will not work on a different cannon printer, (though it is worth noting it definitely worked for mine).
Sep 28, 2013 | Office Equipment & Supplies
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
Canon mx410 paper jam error
For me on my Cannon MX410 with a "paper Jam" light displayed this WORKED!! The absolute BIZZARE thing was after I went and through the described procedure above and rebooted and tried to print the 1st page that came out had a "crushed" ****-roach on the 1st page! So I didn't have a paper jam,...but a
ROACH Jam. :) I told my wife, Humm pest service not workin I guess! It errored out again, but simply unpluggingUSB and power cord (not the steps described for the Print Spooler) it prints fine. SO saved me buying a new printer which was just 6 mos. OLD and FINE by me! So THX, Vikram Kumar Thumu!
Jan 28, 2012 | Canon Pixma MX410 All-In-One Printer
Printing double-sided when paper jammed badly. Every piece of paper has been removed, even the roller dismantled but screen still showing paper jam. The machine is a LaserBase MF5700.
Have you cycled the power, by unplugging the device for at least 10 seconds?
Have you uninstalled or updated the driver to the latest version?
Have you flashed the printers firmware to the latest version? (http://tinyurl.com/3plugrs)
May 23, 2011 | Canon LaserBase MF5750 All-In-One Printer
Shows check paper size on the printer and does not print
your paging has an error in delivering to the printer. the output and the original must be the same. or the out put must not be greater than the original because some printer has an auto resizing option.
Feb 22, 2010 | Canon LaserBase MF5750 All-In-One Printer
My canom laserbase mf3110 print only one page
Well, when it comes to PDF files i found a solution. When u click the "print" icon, u get the "print" window. If u leave it as is, u will get a format/paper size error when trying to type several pages, as described by u. However, if u unmark the "Choose paper source by PDF page size", it will print as many pages as u want.
So...If u have trouble printing pages, it may work if u turn your pages into PDF format and follow the instruction above :)
Dec 20, 2008 | Canon MF3110 All-In-One Laser Printer
"always getting check paper size"
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
Dec 08, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Canon Laserbase MF5650
Only thing I do is to re-boot the printer and check your print size is the same as the paper size in the printer.. pretty poor this
Sep 04, 2006 | Canon LaserBase MF5650 All-In-One Printer
43 people viewed this question
k24674
jasbo
jasbo
