Question about Guess Box Sets W15002G1 WW Watch for Men
My guess watch W15002G1 stopped working after the 4 years of loyal service. what could be the problems? I am thinking, it might be run out of the battery life. What do you think?
    President:
  • 2,080 Answers
4 years is about right for the average life of a watch battery.
Just bring it in to any jewellery store and they will change out the battery for you for about $10 parts and labour.
Good luck.
Posted on Mar 27, 2011
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
I have had my accutron automatic vx-200 for about 4 years and has worked flawlessly until now . The watch keeps stopping , I move the hands manually with movement of the crown and will work for a few hours...
It could be that it needs cleaning. (When a watch is described as "automatic", it means that it is a mechanical spring driven type which needs to be worn constantly to keep it wound up; I assume that yours is one of these.)
Most makers recommend regular servicing at intervals of 2-3 years and as your is older than this, then perhaps it is time for a trip to their nearest service center.
Go to bulova.com to find your local service center.
Jun 05, 2011 | Accutron VX 200 Automatic Chronograph ,...
My Lady Ambassador watch stops every night between 11:45 and midnight (I do not sleep with it on.) In the morning, I reset it and it runs fine - until night time. The watch is less than a year old.
Does your watch have a date change?
The date usually changes about this time and it could be this that is stopping it working. Having it serviced could solve the problem, it it hasn't had any attention for a long time.
Sep 20, 2010 | Wittnauer Watches
Hi I've had my Tango for approximately 8 years and never experienced a problem with it, yesterday I noticed that the second hand moves in five second bursts but still maintains the time well. Any...
Usually a delay in the second hand means a low battery. If you have not had a battery changed in awhile, then thats my best guess. RW suggests a routine maintenence about every 3 years. They have an awesome website. You can read more and get instructions if needed at following link:
http://www.raymond-weil.com/EN/Swiss-Watch-Company/After-Sale-Service.html
Best regards!!
Aug 21, 2010 | Raymond Weil Tango 5560-STP-00328 Wrist...
Tag Heuer 2000 Automatic not moving
Sounds like your watch is in need of service. All watches need to be maintained and regular service is required. A watch is a tiny machine. So if you think about it a car needs regular maintenance to keep it running and so will any machine.
In a watch the oils dry out after about 3-5 years and they stop lubricating. Just like in a car when the oils stop lubricating the engine will stop, a watch will stop.
The reasons for this are 1) no lubrication means high friction on the moving parts. 2) the dried oils become gummy like glue and hold the gear train in place which keep the gears from moving.
The only answer is to have your watch serviced to get rid of the old lubrication, clean and replace any worn parts, then reassemble and lubricate, and finally adjust the timing.
This is something only a watchmaker should do as the parts in your watch are very small and very fragile. Improper handling can permanently damage the parts.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 24, 2010 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Watch only works when not worn
You may not believe me - but I think it is You.
There are some people who stop watches from working - and affect electrical items.
These people are called SLIders - because of the original research on "Street Light Interference"
Be very careful around electrical items when you are stressed - or you could blow lightbulbs.
- Or it could be temperature this watch is responding to. If it stops when left somewhere warm - it's temperature related.
Feb 07, 2010 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
I havent worn this watch for about a year the battery has 10 year warranty and was working fine.now it has stopped working.
A few watch companies...Bulova being one of them used to give a 10 year warranty but I dont know of any batteries that actually last 10 years! The average life of a 1.5 volt silver oxide battery is 2-3 years (sometimes a smidge longer) depending on the age and condition of the watch. A 3 volt lithium battery will get on average 3-4 years.
Im guessing that your battery is probably dead! :-)
Jan 18, 2010 | Bulova Marine Star 96C30 watch
Where is a guess watch service center in India? My new watch (about 4 months old) has stoped working.
http://shop.guess.com/StoreLocator.aspx
follow this link to find the Guess watch retailer nearest you. They should be able to repair it or send it out for repair. Also, if you bought the watch locally, not on the internet, the dealer may replace it for you seeing as the watch is so new.
Oct 19, 2009 | Guess Watches
My tag heuer 2000 chronograph professional button hard to press
Yes it would seem unlikely that the dial would cause this problem. It is more likely to be the seal if the pusher seems hard to depress. Watches should be serviced every two to three years at which time pusher seals are usually replaced. Recommend you take it to a watchmaker for a service to maintain the watch properly.
Jul 27, 2009 | Watches
Stopped running
Unfortunately watch service is often calculated based on the value of the watch, as insurance, and quality/cost of materials and spares and tools are factors. With the correct lubricant there should be no reason why a quality watch should need that particular job done so regularly, but a 4/5-yearly service is not a bad idea at all, as most problems with this sort of watch can be avoided with regular maintenance. Hope this helps :)
Jan 10, 2007 | Ebel 1911 9080241 wristwatch
Guess Box Sets W15002G1 WW Watch for Men Logo
522 people viewed this question
Top Guess Watches Experts
Ansel Alberto
Ansel Alberto
Dennis Fitzsimmons
Level 1 Expert
Are you a Guess Watch Expert? Answer questions, earn points and help others
