Question about Onkyo TX-SR705 Receiver
We wired our new home to have outdoor speakers and also speakers to our pool room. Before putting the receiver back into place after wiring the back, we quickly touched a speaker's wires to the wires coming out of the ceilings and DID have sound. When hubby hooked up the outdoor speakers yesterday, no sound. When we try to adjust the sound level of zone 2, we get the message that it is "out fixed". Can't figure this out. Nothing in the manual about this. What do we do?
    Brigadier General:
  • 8,546 Answers
It's not really clear if all of this is Zone 2 or not, or if you intend a second program to play in Zone 2.
If your Zone 2 is to a powered amplifier and its speakers the Zone 2 output would be FIXED (not variable from the host TX-SR705), that is, at a level that the receiving amplifier would control.
Page 99 deals with it.
Having just passive speakers in Zone 2 requires you to set Zone 2 to "ACT(ive)".
Posted on Mar 27, 2011
How to put speaker wire back into the clip to plug it in the receiver
Press down the tab, insert the wire in hole above it and release
Aug 08, 2016 | Samsung 5.1 Channel 3D Blu-Ray Home...
Tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
on Aug 13, 2010 | Audio Players & Recorders
I have bose speakers connected to a sony receiver and I want to chance the sony receiver to a bose receiver without changing the wires on the speakers. The sony receiver was old and has stopped working. ...
Hi.
Even though you may need to put new plugs on the ends of the wire, you can still use the wires without having to go out and by new.
Places like Radio Shack, Fry's, Ovation, BestBuy, and CompUSA all carry wire plugs that you can install yourself rather easily on the old wires to make them work with the Bose receiver.
Putting plugs on the ends of the wires is really a simple thing to do.
Just follow the instruction that comes on the pack, and you should be fine.
I don't blame you for wanting to utilize the old wire, it can get expensive to replace speaker wires.
The plugs are a cheap way of saving wire, and saves you quite a good deal of money as well.
I hope this helps you out, and good luck !
Jun 07, 2011 | Bose Cinemate Digital Home Theater System...
The back speaker wire isn't long enough to reach to the back of the room. How can I splice the wire and still get it to hook back up to the receiver? Please give a very detailed description, and video or...
buy some speaker wire and wire nuts
cut speaker wire for the speaker and strip back the wire on both ends
cut length of speaker wire required for installation and strip both ends
connect one of the wires to one of the new wires and twist together and then twist on a wire nut... do this for all four individual wires making sure that you don't cross the wires by twisting the new wire.
connect and check. if you don't hear any sound or it is really low, untwist one side of the wires and exchange them.
Mar 13, 2011 | Philips HTS-3555 System
How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Jun 02, 2009 | Philips MX6050D System
Lost almost all sound in both speakers
Test the speakers on a bench if possible with a different receiver and some new wire. Or if you have a multimeter check the impedance, should be 8ohms if it's got a short, it will read 1..... or ....1 If the speaker wire when connected to the outdoor speaker is not siliconed, it acts as a wic and will oxidize the wiring and cause a short. do you have a separate volume control for them? and is that volume control indoor or outdoor? is it connected to a receiver or amplifier? The fastest test though would be to hook up the rock spkrs directly to another unit. If you still have trouble, reply and I will help you troubleshoot further. Hope this helps
May 24, 2009 | Insignia Simulated Rock Outdoor Speakers...
Mismatch of stereo receiver outlet to connector wire.
There are adapters available at Radio Shack for connecting almost anything to anything.
Not knowing which connectors you have, I can't tell you what to get, but if you take what you can with you and explain the rest, they should be able to give you the correct adapter.
May 09, 2009 | Audio Players & Recorders
Turn off audio to speaker A while keeping B on.
HI...
If youre running 5.1 Home theater in one room you wont be able to just switch to the other room with 2 speakers without changing the receiver settings to "Stereo" mode
Apr 10, 2009 | Audio Players & Recorders
Connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
Apr 04, 2009 | Audio Players & Recorders
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Onkyo TX-SR705 Receiver Logo
257 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
