Problem on Toshiba e-studio 45
Good day! I still encounter the problem wherein the whole page of the copy is black. I have already change the drum and drum blade. I inspect the primary because i change the screen but still the copy is black. There is a soot or toner on the primary. Is there a possible problem in these part that causes it to produce a copy that is whole black? We tried to change the primary but the new primary causes a dark spots on the copy. I hope you could help me again. I have already ask a technician to overhaul it but still the problem remains.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
I beleive that if there is a problem with the primary you will only get a blank copy not black.
the problem is most likely your Seperation ***'y or the drum.
1- either the sep/***'y is shorting out causing the paper to rise against the drum and putting too much toner output, or the drum has not been adjusted correctly. Did the tech adjust the new drum to the machine? there is a procedure you have to do everytime you change the drum.
Posted on Aug 08, 2008
HOW DO I CLEAN THE MACHINE SO IT DOESN'T LEAVE A BLACK GRITTY RESIDUE ON PAPER CHANGED INK ALREADY
Get an inexpensive toner vac if you are cleaning a spill. If the pages are coming out of the machine with toner on them can you post a pic?
Mar 27, 2014 | Toshiba e-studio 255 Copy Machine
The developer box does'nt keeps toner in it, is it probably because of already 'old developer' or do i need to add some developer...how much is developer? Mine is toshiba e45. Thanks a lot.
Hi
The developer life span is about 150.000 copies, then it should be replaced.
If the developer has not done 150.000 copies then there could be another problem.
The cost of the developer is about R1000.00. {in South Africa}
Please remember that the life span of the drum and drum cleaning blade is also 150.00 copies, so the developer, drum and cleaning blade should be replaced at the same time.
Regards
Apr 12, 2011 | Toshiba e-Studio 45 Black and White Copier
Why is my Toshiba estudio45 copier copies coming out black pages?
check the main charge carona wire and the transfer and separation carona wires if all the carona wires are intact then the hvt board could be faulty
Mar 29, 2011 | Toshiba e-Studio 45 Black and White Copier
When I make copies, its doesn't come out clear and smudged.
Needs the drum unit cleaned. There is a green stick you can try pulling in and out on the front of that module. Also may need a developer change.
Jul 26, 2010 | Toshiba e-Studio 45 Black and White Copier
E-studio 45 is developing faint print generally, with some areas lighter in a mottled pattern. It has a new toner cartridge. Serviceman says he is not sure of the cause. He cleaned the inside, after...
I would call the service company and ask for another tech to look at the problem..... Yes the problem could be caused by the developer. I could also, be caused by the opc drum or the charge roller... Good Luck
Jun 11, 2010 | Toshiba e-Studio 45 Black and White Copier
Our Toshiba e-studio 352 is leaving a black line down the front of pages that are printed. what is the problem?
If u copy through feeder, then probably is the scanning mirror dirty. If u encounter this problem when printing from pc, then probably is process unit or t/s block problem.
Jun 04, 2010 | Toshiba e-Studio 350 Copier
My e-studio 45 has 260,000 copies and says it needs maintenance. It works well. Do I just replace the drum or does it need other parts like a fuser too?
Hello sir; When it said need maintenance, it means need PM( periodical maintenance) that including drum, drum blade ,developer, corona wire, etc. the fuser and pressure roller depend on condition.
Feb 01, 2010 | Toshiba e-Studio 45 Black and White Copier
Toshiba e-studio 45
you must have to change primary
Aug 05, 2008 | Office Equipment & Supplies
That should be looked at by a technician to check the optics out
Jul 13, 2008 | Office Equipment & Supplies
jasbo
jasbo
