Question about Toshiba 37WLT66 37 in. LCD Television
Hi. The set turns on, recieves the picture and sound, but the display is so dim, you cannot view anything. If you are young , with good eyesight you can just make out what is on the screen
  • robert_jean2 Mar 27, 2011
    Sorry, forgot to mention, when the set is first turned on, not from standby, the screen appears normally for a few seconds, then goes off. The set has been given to us and the remote has been lost.
  • 822 Answers
Could be screen back light................easy fix...............
cheers
Posted on Mar 27, 2011
  • 2 more comments
  • paul
    paul Mar 27, 2011
    ok.....still sounds like back light.....
    could be bad connection only way to find out is total strip down............
    not as hard as it may sound................
    cheers
    Thanks for that, I'll give it a go in the morning.
  • paul
    paul Mar 27, 2011
    ok
    before you get to involved with stripping it down. switch it on as normal and very lightly...............tap around the top edge with your fingers to see if it flickers.......
    if it does .......will give indication as to ware lose or bad connection may be............
    good luck
    cheers
    Great idea, thanks again.
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Mar 02, 2017 | Televison & Video
A6750y computer locks up after ten minutes surfing
Hi David,
Good day.
Solution for Windows
Steps:
1. Click Start > Control Panel
2. In "View by:", choose "Category"
3. Click "Hardware and Sound".
4. Click "Power Options".
5. Click "Choose when to turn off the display." It is found at the left side pane menu,
6. Change "Dim the display" to "Never".
7. Change "Turn off the display" to "Never".
8. Change "Put the computer to sleep" to "Never".
9. Click "Save changes".
Please click the drop down box in to change the value to "Never". DO NOT use keyboard (e.g., tab, arrows.). Use only mouse and click then save changes.
Thanks.
Dec 03, 2013 | HP Pavilion a6750f PC PC Desktop
Hi, I've got a 1959 Zenith C3012H. It has sound,
Dim picture can be of many causes. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 29, 2013 | Televison & Video
When i turn on my samsung pl50, a totally white and bright screen appears and its impossible to view anything on that screen. All other functions are working. Its capturing pictures as well. But the...
Sound like a problem with your LCD screen, related with the CCD Image Sensor; since that you can view mode and setting displays, isnt the LCD screenviewer.
The CCD Image Sensor isnt a job that you can do it, I suggest visit your techinician service or apply if has underwarranty.
Good luck.
Oct 16, 2011 | Samsung SL202 / PL50 Digital Camera
Sound no picture Polaroid 15.4 TLA-01511c
If you take a good look at the screen when it goes dark can you make out anything maybe some bright scenes on the channel you were watching or if you press the menu key, you can see a very dim display, you might need the back light assembly or something related to it.
Jan 09, 2010 | Televison & Video
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
Dim backround and display on westinghouse LTV-40w1 HDC tv
u will have to go into service menu to set sub brightness be carefull u may do more bad than good write down all valus before atempting to adj.
Dec 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Image through view finder is blury
Hey DarsCanonFix,
This camera does have a diopter adjustment on the viewfinder to correct for bad eyesight. I would try adjusting this since it could have been accidentally set incorrectly. If this doesn't work the camera might just need a good cleaning by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Canon PowerShot S3 IS Digital Camera
The picture is not lined up on the screen it is off to the right and we cant find anything in the menu. we also have bell express view is this a reciever issue?
sounds like a convergence issue. What is the model number of your set and I should be able to help you out with it.
May 03, 2008 | Televison & Video
Colour problems
Your CCFL lamp has reached "end-of-life". They go pink when they are old. You can get replacement lamps here: http://jkllamps.com/index.cfm?action=fam&tid=2&fID=45 They can also help you with the job, better consult them before ordering anything. Good luck
May 14, 2006 | LG 17LX1R 17 in. HD-Ready LCD Television
Toshiba 37WLT66 37 in. LCD Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
