Question about QSC RMX-2450 Car Audio Amplifier
Was playing a show and my qsc rmx2450 starting tripping its internal breaker, when we reset it, both clips would come on and throw the breaker again, any ideas?
2 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: Soon as i turn on my QSC RMX2450 the clip light comes on for Ch 2
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
Posted on Sep 14, 2009
Rv ac throws breaker. what all is wired to the breaker?
You can narrow it a bit. Turn the ac off and reset the breaker. If it trips then you have a short to ground likely BEFORE the machine. If it does not then it's internal. Only turn the fan on, no heat or cool. If breaker trips then it's in the blower. If not, turn on cooling. If it trips then, likely in compressor. Good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 21, 2017 | Heating & Cooling
Keeps shutting off after a few minutes of play
Probably an internal breaker tripping, which then resets, and will trip again. Possibly something more damaging happening inside the pedal, hence why it is tripping off. Suggest taking to a service center.
Jan 19, 2014 | VOX StompLab IG Modeling Effects Pedal
I need the schematic for QSC RMX2450
HI,
if you can provide your email address the i will sent you the schematic diagram . Its not possible to upload PDF files here.
Ajin
Apr 30, 2013 | Audio Players & Recorders
Power is connected but dishwasher will not start
Make sure (with and electric field tester/2-prong tester/DMM/VOM) that there's 120VAC to your
dishwasher. You can also check the circuit breaker - it may be OFF or TRIPPED.
Its easy to see when a breaker is OFF, but harder to see a TRIPPED breaker - the toggle
stops halfway between ON and OFF when a breaker trips, and its easy to miss in the dim
light of a typical garage or basement (this electrician knows from experience). To reset
a TRIPPED breaker, you must throw the toggle
switch to OFF, then reset it by throwing the toggle to ON.
If your residence has a fuse panel, check you fuse and consider buying a reset-able screw-in
replacement from your local electrical supply.
Feb 20, 2011 | KitchenAid Dishwashers
Breaker breaks
This unit may have an internal overload mounted on top of the compressor. You would have to get to the
compressor to find out and it maybe faulty. That may
explain why the compressor comes on later on, this
overload protects the compressor from getting hot.
When you trip the breaker and then reset it again only to see it trip again almost sounds like a direct short or loose wire. It could also mean that your
capacitor needs to be replaced or that you need a hard start kit and the unit needs a good cleaning.
Try just operating the fan and see if it trips the breaker, if it does then either the blower motor is bad
or it is still the capacitor.
Jun 25, 2010 | Dometic Rooftop RV Air Conditioner
Won't start
Check the door switch by listening for an audible click just as the door opens or closes. If you do not hear an audible click then the door switch is bad. IIf you hear this audible click then go to your circuit breaker box and check to see if they have tripped. If the circuit breakers have tripped reset them ONCE and try the dryer. If the breaker trips again DO NOT reset it. You have an internal short in your dryer and it will require further service.
Jan 06, 2010 | Whirlpool LER4634J Electric Dryer
Sep 07, 2009 | QSC RMX-2450 Car Audio Amplifier
Performa washer is throwing breakers if you trip the breaker it will start back up and may work several days but trips again
hello there;
you need a bigger amp breaker fuse, look in your manual it willl tell you. for example you got a 25 amp use a 30 amp fuse instead.
Aug 17, 2009 | Washing Machines
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
QSC RMX-2450 Car Audio Amplifier Logo
66 people viewed this question
Top QSC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a QSC Car Audio and Video Expert? Answer questions, earn points and help others
