Question about Sony Walkman TCD-D8 Personal Cassette Player
Won't respond to good batteries
I just got a used D8 from my uncle and it works fine with a power supply but will not start with batteries.  I have tried several known as good sets of battries but it won't turn on????
thanks for any ideas on this
    Problem Solver:
  • 4 Answers
Check and clean the contacts.
Also if you take the back cover off, you can see the red and black battery wires connected to the board. Make sure they are connected.
Posted on Jan 29, 2009
Just replaced the power supply Backlight inverter to Vizio Model E470VL TV. It works fine now but I can't get the remote control or a Universal remote to work. Do I need to purchase a special remote?
If the remotes have good batteries and are both working, and the set still does not respond, you might try to reset the sets electronics. If that does not do the trick then the board responsible for responding to the remote signals generated has an issue.
Feb 23, 2017 | Vizio Televison & Video
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
Laptop has power but won't boot up
There are three possible reasons why it's acting like that.
1. Defective AC Adapter or Power cord
2. Defective Motherboard
3. Defective Battery
First off, you need to isolate the part which causing the issue. Please follow the following steps:
1. Remove the battery and use the power cord alone in powering up your computer. If it goes well, then you need to replace the battery. If no go, then try using a different known good outlet.
2. Check the acer power adapter (the box) if there's a light lit. If it's green, then it's should be working fine. If it's amber or nothing at all, then there's a problem with it. You might need to replace that.
3. If the AC adapter looks good, then try to wiggle the cord so that you can check if the cord is properly connected to the computer. Usually, cords get loose and it causes problems. If it has this kind of problem, then you need to get a technician to check that for you because you might need to buy a new motherboard for that.
Please do the above simple steps, and let me know if anything happens. I hope this can solve the issue.
Feb 13, 2013 | Acer Aspire One PC Notebook
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
Dec 22, 2012 | Samsung PN58A550S Plasma TV
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
All lights on wont shut down wont respond
Hello, maybe you have to do what i call hard reset, unplug it from the light then look round if you can locate any fuise on the print take it off, then allow it for 1hour and try again later
May 07, 2011 | HP Deskjet F2210 InkJet Printer
My ACER 5570z will not start up. When power cord
You most likely have a broken DC Jack on the motherboard. Thus, the battery cannot get a charge and the power supply is not making a connection to the system board because of the broken DC Jack.
Good Luck
Sep 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
Sony Walkman TCD-D8 Personal Cassette Player Logo
115 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
