Question about RCA G36705 36" TV
I have a rca g36705 36" all of sudden it started changing channels all by it self and it would shut off until i unplugged now it won't turn on
    New Friend:
I have the same T.V. with the same problem and I talked to a local guy that use to work on t.v's and he told me that it was the part that plugs into the board in the back ,where the off & on buttons are. I took it apart and he was right .I just need to find out where to get the part
Posted on May 10, 2013
5 Suggested Answers
SOURCE: power turns on and off by its self
The problem is the key board controller is malfunctioning. I have contacted a multitude of supply houses even
RCA included and I have not been able to buy the part. However, you can bypass the problem by disabling the key board functions by activating the parental control item, not the password, by using the remote. All the keys on the front panel will be disabled but you can still operate the tv with the remote plus save yourself a cost on parts and labor.
Posted on Apr 13, 2008
johnnydiode
  • 647 Answers
SOURCE: I have an Rca 36 inch tv, the color is messed up,
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 24, 2009
demonicsaint
  • 160 Answers
SOURCE: Stuck on 1 channel
Get a cable box from the cable company it will be cheaper than repairing the tuner. Then you use the tuner from the cable box instead.
Posted on May 07, 2010
SOURCE: G36705 36" TV: I purchased a used RCA G36705 36" TV and it shows ...
crackling intermittent signal <!-- from fixya rte -->
Posted on Aug 15, 2010
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Constant horn that won't shut off
This could be three things.
1. The relay is stuck, this is under the hood and is probably not the issue.
2. There is a wire in the steering column called a coil spring and it could be broken or damaged.
3. The actual switch on the steering wheel has a short in it.
Jan 17, 2013 | 2000 Jeep Grand Cherokee
While watching my sony KDL-46NX810 TV its suddenly shut off and starts blinking 3 times red standby light. Please have me inform, what this error means and how to repair or what to replace on my...
Hi Gerard,
3 flashes of the led light on most KDL series is a power supply malfunction. To confirm the error code, lets access the self diagnostic screen by following the steps below.
Unplug the unit from the outlet for 30 minutes and then plug it back in and check if the symptoms remain the same. Wait until the led light stops from flashing and then press in rapid sequence the "Display", "Channel 5", "Volume (-)", "Power" button key on the remote control. Self diagnostic screen will be display. Let me know the result.
Jdvillanueva
Nov 09, 2011 | Sony KDL-46NX810 46 in. 3D LCD TV
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Oct 18, 2009 | RCA Televison & Video
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
RCA TRUFLAT VOLUME,CHANNELS MOVE ON THERE OWN
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to www.tv.rca.com/ there are free manual there
Jan 25, 2008 | RCA TruFlat 27F520T 27" TV
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
CHANGING CHANNELS ALL THE TIME
I have seen some RCA TV's with this problem and it has usually been a switch going bad on the keypad of the tv. This can be confirmed by disconnecting the plug from the control panel to the main chassis.If you are lucky, and the ir rcvr for the remote is not on the control board, you can still control tv with the remote.Good luck.
Jul 25, 2007 | RCA F32444 32" TV
RCA F32650
I let it go and she corrected by herself. What do you think?
Aug 14, 2006 | RCA F32650 32" TV
RCA G36705 36" TV Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
