Question about LG BD350 Blu-Ray Player
Hello, my lg bd350 blueray player is frozen while boots up. I cant open the tray. When I press the eject button, it writes open and close but nothing happens. The only way I can get to the menu, if I turn on the player with the eject button, and when the player is booting I plug in the USB stick. Then I upgraded to the newest firmware, but the problem still exists.
SOURCE: LG DVD 6053 Disc tray does not open
This happens to my dvd player all the time. I know this sounds bad but I give it a few quick taps on the top of the player just after I press the open button and it opens for me. I have the same player as you also.
See how you go with it!!
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: Disc removal
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Posted on Aug 11, 2008
if you take the dvd player part out, the gear at the front will open the door! you'll find the drive motor and belt under there! you'll more than likely find the belt is either too big or broken!
Posted on Sep 08, 2009
SOURCE: LG BD390 Disk Tray does not open
unplug power for 90 seconds, reconnect.
Posted on Dec 10, 2009
1. Try press power up button 10-15 seconds.
2. On some players lost contact in the interconnect plug. Open case and check connections.
Posted on Feb 17, 2010
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Tip
The CD/ DVD/ Blueray player tray keeps opening and closing!
First make sure the "Eject" button has not stuck while pushed-in. Clean the Tray window/opening and the inside of the front part of the tray. Then try to push the tray in a little bit when closed and drag it out while open! By the time dust gathers on the greasy tray rails resulting it not to open and close to the full extent. If it helps but the problem comes back, then you should open the box and clean the rails more thoroughly. Have a look at the switch that senses the tray state (open/closed) too. OBS! That is not the same as the "Eject" button! Switch placement is device model deppendant but it is usually placed on the stationary part of the disc-player unit under the front end of the tray in the middle!
Some units do eject a disk they don't recognize. That a player can't read a disk could be a result of incompatibility, dusty optical lens or faulty/old laser. You may clean the lens by using a "Cleaning disk" or blowing with an air spray(or a straw with your mouth) through the opening of the tray.
Good luck
Please rate positively if helpful, thanks!
/SciPhinx
on May 06, 2010 | Televison & Video
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
Looking for code for LG BD 350- can anyone help!
Download this file unzip it to a folder on your hard drive: http://www.multi-region.net/_media/6000.zip
Burn the downloaded file RMTMOOOO AND ITS CONTENTS onto a CD disc. Make sure the disc is then finalized and closed
Load disc into the BD350. A screen appears asking to assign a number in a DVD and a Blu-ray fields; use the up/down arrow keys to place a "0" in both fields; the, press the "pause" key. This will render the BD350 region-free (for DVD's) and zone-free (for Blu-ray discs)
Sep 14, 2009 | Pioneer DV-350 DVD Player
How to unlock code for LG dvd player model DVX183?
Hi, have you tried this? It worked on my LG player.
1. Open DVD tray
2. Press "0000" on the remote.
3. A screen will appear saying NEW REGION CODE displaying the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD tray.
7. Power off
Feb 21, 2009 | LG XBR446 DVD Recorder/VCR
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
LG BD350 Blu-Ray Player Logo
306 people viewed this question
Computer Repairing
Computer Repairing
