Question about Vacuums
The battery for my grass strimmer no longer takes a charge. Where can I get a replacement battery please?
    Sergeant:
  • 259 Answers
Try Sears or Home depo.
Posted on Mar 27, 2011
My Roomba 561 will only run for about 30 minutes and then needs to charged. Is there a way to charge the battery longer?
The battery may be getting old and unable to hold a charge. I would recommend checking with the manufacturer about replacement batteries.
Mar 11, 2018 | Roomba Vacuums
Dyson 45 is no longer charging
Most likely your battery needs to be replaced.
It's probably doing a "false charge", it's like having a rechargeable D-cell but internally only the equivalent of a AAAA-cell is working, only a more extreme version of this situation.
It would charge up very quickly but also discharge very quickly and not really power anything.
The charger doesn't realize that it's only taking seconds to charge the battery, it's just checking if the voltage is up to a full charge level.
Sep 06, 2016 | Dyson Vacuums
When battery has been fully charged, the charge only lasts 1/2 hour before it needs to be re-charged.
I would assume that the battery is old. With time batteries looses a bit of charge, and their life get worse. You should just buy a new battery and the device will work longer for sure.
Oct 19, 2015 | Shark SV1106 Navigator Cordless Upright...
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Battery flashing
Normally a battery flashing is an indication that the battery either needs to be replaced or is low and needs to be recharged (if it's rechargeable)
Bear in mind that rechargeable batteries, such as those used in the robot-controlled vacuums do not have an infinite life. There will come a time when it will no longer take (or hold) a charge and have to be replaced. If this is your situation, take the vacuum (along with the charging station) over to a place called "BATTERIES PLUS BULBS" (there are stores all over the US) - these guys can very often rebuild the battery pack for less than half the cost of replacing it.
Good luck!!
Nov 01, 2014 | Vacuums
Brand new : battery charges to 60 minutes ( 8 hours)and by the next day is completely discharged.
It sounds like the battery has a faulty cell in the battery that never lets it hold a full charge or lets it bleed off. I would take it back and exchange it.
Could you provide a model number?? There may be some settings on the vacume that are continuing to use power even though it is not in use.
Thanks
Apr 11, 2010 | Vacuums
Roomba 550 was plugged & docked in for 3 wks without being used (on vacation) & now it won't work or charge. Unit is 3 months old.
The battery sounds like its dead.. Leaving it on a constant charge is actually bad for the battery. Sorry to tell you but you need to either get a new vacuum or take it back to the place you got it and have them take a look at it and perhaps replace the battery.
With the money you spent of that "vacuum" you could of bought a much better vacuum cleaner that would last you much longer.
Also, if it's only 3 months old I'm sure there's some kind of factory warranty in place for something like this. Give the manufacturer a call and see what's up.
Hope this helps you
Mar 23, 2010 | iRobot Roomba 560 Robotic Vacuum
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Rechargeable battery does not recharge
They are nickel cadminum batteries, and are replaceable, you may have to order from a repair shop, or go thehooverstore.com. Once you have the battery pack out, maybe you can find them like at Radio Shack or other places that sell these type packs,
Oct 15, 2007 | Hoover S2105 Slider Bagless Stick Vacuum
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
