Question about Cycling
I have a bicycle (Cannondale Bad Boy SOLO Ultra 2009 white edition) and I can't find a front mudguard that will fit the front lefty soli fork setup. Any suggestions?
    Brigadier General:
  • 8,546 Answers
I have a set of SKS X3's for my Jekyll with a Lefty. The front has a special large insert for the headshock-sized opening at the bottom of the steerer tube. Maybe check with a Cannondale-shop to find one.
Here's another solution at the bottom...
http://www.bikeforums.net/archive/index.php/t-277507.html
Posted on Mar 27, 2011
  • davbeau Aug 13, 2011
    I'm looking for a Solo Ultra white edition- fancy selling yours?
    02074194181
  • David Dunn
    David Dunn Aug 13, 2011
    You may have some luck lurking around the auction sites, maybe cop a frame and build your own. You don't even know what size his bike is, nor say what size you want. There's a black '08 medium on eBay.
How do I fix an oil leak on my cannondale lefty
First try to replace the oil and replace the oil seals then inspect the tubes for scratching/gouging while you have them apart.
Sep 25, 2014 | Cannondale Lefty Alloy Dlr Mountain Bike...
Stripped threads in accessory holder for cannondale ultra.. How do I remove old ones and install new.. Drink holder won't tighten down due to bad threads.. Any ideas
I am assuming you are talking about the bolts in the frame for the water bottle holders. You can take it to the bike shop and have them install a "Rivnut." This entails drilling out the frame boss that is stripped, and installing a Rivnut with is a rivet that is threaded for a specific size, in this case, the same size for cage bolts. Or you could order the kit and tools yourself, but then you would be left with extra Rivnuts and tools.
Dec 09, 2012 | Cannondale Bad Boy Ultra
Shipping a bike. dismantling instructions; front fork in particular
Since there are a lot of varieties of the Lefty go here and search the list for "LEFTY".
http://www.cannondale.com/manuals
Or you might just get away with deflating the pressure preload and collapsing the fork.
Jul 02, 2011 | Cannondale Lefty Alloy Dlr Mountain Bike...
I just bought a used Cannondale lefty fork. I was told that it can be stiffened by placing a pump on the bottom of the valve to add air into the fork. Problem is, the valve stem is so encased in the fork...
Hello ledpencil,
Pneumatic bike shocks require a special type of pump called a "shock pump" that is a high-pressure (up to 300psi!) but low-volume pump. They come with a very accurate gauge, pump handle, and a bleed valve/button to let off puffs of air to soften the shock. They also have a long flexible neck that screws onto the valve at the base of the fork. They're relatively small and moderately priced ($20-$40) and can be packed in a riding pack in case you want to change the stiffness on the fly. Here's a link to some online: http://www.jensonusa.com/store/sub/292-Pumps+And+Co2+Inflation-Shock+Pumps.aspx?s=1559&mfg=0&closeoutHotdeal=&use=&sort=Default&show=25&pricemin=0&pricemax=100
Hope this helps! -The Chicken
Apr 01, 2011 | Cannondale Lefty Alloy Dlr Mountain Bike...
The lefty tops out, especially when climbing. Can this be fixed?
Probably. Is it the old original Cannondale Lefty with the pre-charge pressure fitting at the bottom or the newer (MARZOCCHI??) style. Either way, a real bike shop will have the high-pressure/low volume pump that is necessary if you don't want to purchase one yourself.
If the problem is mechanical (like blown seals) they'll also have the special tools, parts, fluids and skills to resolve it. Shock service isn't for the uninitiated to handle solo.
Jan 06, 2011 | Cannondale Jekyll 1000
Will the cannondale xc3 mtb stem fit on my lefty headshock? And how do I do it?
the XC3 stem comes in a 1.5 in clamp designed to fit on cannondale headshox systems. The lefty fork you have may or may not be compatible, you would have to check your fork to see if it is the right size.
There is an XC3 SL conversion kit for lefty forks that are not the same size and includes the stem and steerer replacement.
Swapping stems is quite easy on the cannondale. Loosen the two bolts holding the stem to the steerer and undo the bolts holding the handlebars, remove stem and replace.
If none of this makes sense then I would strongly urge you too take the bike into your local bike shop, preferrably a cannondale dealer, and have them show you. It will take only a couple minutes and they can confirm compatibility.
Jan 06, 2011 | Cycling
How to dismantle lefty
Hi!
The Cannondale Lefty fork can only be disassembled with speciality tools. You can read illustrated instructions here: http://www.gordlaw.com/index.php?Cycling:Cannondale_Lefty_DLR
Please check that your Lefty fork is identical to the one described, as the process and tools are different for the various Lefty editions.
As a warning, dismantling the fork could lead to serious injury if you don't know what you are doing. Please read through and understand all instructions before deciding whether to do it or not. Good luck.
Apr 04, 2010 | Cannondale Road Mountain Bike Bicycle U...
Cycling Logo
393 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
