Question about Amana Refrigerators
We get a pool of water on the floor during the defrost cycle.
    Sergeant:
    Champion:
  • 202 Answers
Hi.... you have a plugged drian... water can't run down the drain ... Thats why your getting water on the floor ...
Posted on Mar 27, 2011
Water pooling and freezing on bottom of freezer compartment. Where is it coming from??
If you have an ice maker in there it could be that there is too much water entering the tray and the excess spills out. OR the drain that gets rid of melted ice during the auto defrost cycle could be clogged and the water stays in freezer, pools and refreezes.
Oct 08, 2015 | Refrigerators
Why is there a pool of water in on the floor after a defrost cycle?
Could be a clogged drain tube. Try examinng the drain tube if it is transparent. You could also try snaking it out with some sort of wire to see if it clears a clog. Blowing air through it could also be an easy way to see if it is clogged.
Jul 18, 2014 | Zanussi & Electrolux Fridge Freezer Handle...
My fridge model CTF2123AR leaks water under bottom pull drawer. this pools water on the floor
Water found under the tray is due to excess defrost specially when the fridge is set to a lower temperature due to heavy frosting.
So during defrosting the excess water flows into the tray and overflows out which incidently has flooded on the floor.
What could be done is to drain off the tank, fully defrost the fridge by shutting down for few hours and then setting the fridge/freezer to a normal temperature.
Jul 13, 2011 | Magic Chef Refrigerators
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint ctx18 ref has water on floor on defrost cycle
Look on or under the compressor. There is a drip pan there.
Eric
Jun 29, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Water leaking from freezer
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle.
May 18, 2009 | Kenmore 64802 Top Freezer Refrigerator
Fridge is leaking onto floor
check the "drain pan". during defrost cycle it is filled completely.Try to shift the water out of it during every defrosting cycle.
Dec 22, 2008 | Refrigerators
Water on floor
prbably clogged drain. remove lower bin and clean ice from drain with hot water in squirt bottle or a steamer.
Jul 27, 2008 | GE Profile PDS22MHR Bottom Freezer...
Refrigerators Logo
42 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
