Question about Maytag Cooktops
I have a Maytag radiant glass cooktop, model CCE3401W. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the knob control. Is it likely I have a bad burner switch? If so, how do I access it for replacement? How do I dissassemble to access the inside parts.
3 Suggested Answers
SOURCE: I have a Jenn Air
Did you find the solution for this problem? If yes, can you share it with me?
Posted on Mar 27, 2011
If the light circle around the knob stayed on, then you have the same problem I just had. I purchased a OEM replacement switch via ebay for $38. Very simple replacement, but take your time so you understand how it works. It took an hour to install and works fine now. Here is the link to the parts list:
shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - CCE3401B.pdf
If you can, take pictures with your phone of how everything is assembled before you take it apart. It will save you hours of aggravation.
I must say, Jenn-Aire (Whirlpool Corp) was less than helpful. I asked for some advice prior to purchasing the replacement part and all they would tell me is they were willing to schedule an authorized repair shop to come over. The closest was a 2.5 hour drive each way, and the travel time cost was $85/hour. Plus the part at list price ($90 something) and installation was going to cost $600. Give me a break.
Posted on Oct 22, 2012
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
Indicator light on my maytag electric smoothtop range will not shut off even though the indicators are off?
One of the high heat sensors has failed on one of the burners under the glass. Disconnect one sensor at a time to find out which one, then replace that burner assembly.
Feb 19, 2011 | Maytag MEC5430BDS Electric Cooktop
I have a Jenn Air radiant glass cooktop, model CCE3401B. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the...
Dec 31, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Why is the light burning on my Corning glass cooktop?
well there is some problem with ur knob u should replace it.
Jul 21, 2009 | Verona 34 in. CTG536S Gas Cooktop
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Apr 21, 2009 | General Electric 36 in. Profile PP962...
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
73 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
