Ruud Achiever 90 - Intermittent - No ignition sometimes, ignites other times and turns off after a short while, lastly can get to ignite and stay on also using technique below. Seems to work fine IF I open cover door and let more oxygen in and leave cover slightly open. When cover door if fully closed it has harder time igniting, does not ignite at all, or ignites then goes out shortly thereafter. Need to recycle power to get furnace to go through the start up process. Think perhaps need to clean flame sensor after doing some reading but I am now letting it run to get the house heated up again before I try anything . Just wondering if the fact that it ignites better with cover door slightly open supports the flame sensor theory or ???
  • VIPGNC Mar 27, 2011
    I have a single vent pipe... was planning on making sure there was no blockage but unit seems to be venting OK. Wondering if increased air causes flame to burn hotter (perhaps less efficient) and this is overcoming any build-up on flame sensor. The furnace has been running fine over the last hour or so once i got it started and I am leaving the cover door cracked a little to increase the air flow or reduce the vacuum created inside the unit when the flame is ignited and fans running. Perhaps the increased air (reduced vaccum) inside the ignition chamber is not the main reason why it is working for now but want to get my house temperature back into the 70's before I mess with it anymore.
    Guru:
  • 683 Answers
No it shouldnt have anything to do with the cover, tighten all bolts, grounds, screws that you can find. Find the flame sensor and try cleaning it and also make sure sensor in inside the flame. let me know.
Posted on Mar 27, 2011
  • 1 more comment
    Thanks... problem started yesterday and furnace did not run all night so I am letting it heat the house up before I do any troubleshooting/work on it. Just found it interesting that allowing more air into the ignition section of furnace seemed to help assure ignition. There is also a punchout (hole) in the side of the unit, while I only tried this once (as I want it to keep running to heat house) when I covered it with my hand thereby blocking the air that was being drawn into the unit through the hole the flame went out immediately! This too seemed to indicate that whatever the issue was the restriction or addition of air from outside the unit seemed to have an impact on the ability of the flame to ignite or stay lit. Will let house get heated... look to clean flame sensor... and post followup later in the day. Any other suggestions would be appreciated. Thanks.
  • Walter Kunesky
    Walter Kunesky Mar 27, 2011
    do you have a one pipe system or a two pipe system.
  • Walter Kunesky
    Hi, do you have a pressure switch on unit? this would be a rubber line going from the draft inducer motor to the pressure switch. do you have a way of checking this switch, if not jump the two wires together and see if unit stays running, if the draft inducer motor was going bad, opening the door would allow the load to go down and it blow enought air to keep switch open. Let me know.
My ruud achiever 90 works fine it's producing plenty of heat. It's just that it only shuts down for a few seconds before it reignites then starts blowing again. It's almost continuously on.
Most likely:The thermostat is telling it to come on. If it continues to run with the thermostat set to off,the ignition relay is stuck in the on position, when the ignition is on the heat sensor will turn the blower on on matter what.
Dec 12, 2014 | Heating & Cooling
Achiever 90 plus igniting
be sure the heat anticipater setting on thermosta matches gas valve.
Jan 09, 2014 | Ruud UBHC Air Conditioner
Ruud 90 Plus Achiever furnace starts, ignites, runs for 30 seconds, goes out, then does it again and again.
It would seem as though you have a bad flame sensor or the ground from the burner to the ignition control is bad...
Could be the ignition control also but not nearly as likely...
Pressure switch can also cause these problems...
Bottom line is that you will need to grab a meter and try to figure out what is causing the flame to cutout...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 14, 2011 | Heating & Cooling
"RUUD Achiever 90 Plus" Propane
Hello bikejocky,
MOST LIKELY you have a "hot surface" element
with a tiny crack in it...
About 25 years ago... I put one of my poor abused
fingers on the element to see if it was at all warm...
In so doing I touched the spot where the crack was...
and it did INDEED have a full 120 volt, 60 cycle AC
current waiting for my FINGER to complete the
circuit... (not a recommended procedure)
My 25 year old RHEEM... finally kicked it.
I keep spares... and bought 2 more when I used
the last
Since these parts are pretty cheap... I get spares
62 22868 93 Rheem 62 22868 93 Hot Surface Ignitor
Take a look... There are two basic configurations
The WISEST APPROACH is to use a "meter"
to verify the "line current" is present (not finger)
and check the "SURFACE" for continuity.
Once you copy the number DIRECTLY from
YOUR OWN part... look it up... internet... eBay
and AMAZON (like Robert Shaw #41-408).
http://www.ebay.com/itm/ROBERTSHAW-41-408-Hot-surface-ignitor-NORTON-271N-/121727955205?hash=item1c578d3105:m:mJR3I8e9mTI60A-dtmvdVrw
>> It is the plug & mount that is important...!!
(consider that spare you always wanted
(If you get it... you will probably never need it)).
The cycling limit & fan
(never touched a RUUD... (so... I presume)) is to clear accumulated GAS FUMES to avoid any explosive
situations.
I do know RHEEM... (ERGO... I have every confidence)
((RHEEM & RUUD, in my opinion, are design twins)).
Carnac the Magnificent
May 10, 2017 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
361 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
