Question about Acer (ACERMOTHERBOARD)
Hello, I have fitted 2x500mb DDR ram, new round cables and added a Asus video card with DVI for the LCD monitor, I replaced the battery 2032, when power up the psu, case fan and AVG video card are all working fine and spinning but the Screen stays blake, nothing at all and the monitor goes into stand bye. I hope I have given you enough info to help me.
  • 961 Answers
Start up in "safe mode", Click "start" find "control panel" and click on to open. In your list(icons) find "device manager". Right click on , open and click on continue. Click on the box with + next to dispaly adaptors. You graphics card should be there. Right click on it and you should see "disable", if you see "enable" click on that. Right click on it again, then click on "properties". You should see a window with "this device working properly". If this does not help you please provide: Acer model #, what version of windows you're running and, Asus model #, at "add a comment"
Dave
Posted on Mar 27, 2011
Problem with windows XP and ASUS VE278Q Monitor?
When getting consistant a line that is covering the entire screen vertical or horizontal in any width, is most likely due to a cable or monitor hardware defect.
1.
No matter what cable you are using, then make sure it hasn't been damaged - Sometimes a small dent cause a huge defect.
2.
Try a similar cable or the same cable in another monitor.
3.
NEW PRODUCTS:
Never wait or hesitate to contact the manufacturers support or the store where you bought the product to get a replacement or refund (warranty). Don't use a lot of time trying to repair something that should have worked and which you don't have any knowledge about, it is simply a waste of your time.
Jul 12, 2014 | ASUS LCD Monitor
Third monitor not showing
right click on desktop click screen resolution and press Detect button. Also try updating your video driver. also try swapping out the cables with each other and try using a hdmi cable for the TV connection.
Jan 18, 2013 | ASUS EAH5450 SILENTDI512MD3 RADEON HD 5450...
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more...
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Feb 19, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Acer x223w monitor - unexplained system freezes
is your lcd has a dvi port? aside from vga? and also is your video card has a dvi port? if all these questions meet, first uninstall the driver of your video card. Then, you need to switch your cable, in order to do this, you must place the one end of your cable to the dvi port of the cpu and the other end to your lcd dvi port. and reinstall the driver again of your video card. see if it works. because there is a certain problem that vga port configuration differs from the
dvi port. that's why when playing games, especially online games. sometimes your system will get corrupted.
Good luck! have a nice day
Jan 18, 2009 | ASUS A7N8X Deluxe (A7N8X/DELUX D)...
DVI cable not working
If you still have your old monitor plug it back in for a bit and load the drivers for the new monitor (from the disk which came with the new monitor). Right click on your desktop and choose properties and set your display resolution to something like 1024 x 768. Shut down the pc and connect your new monitor to it with the dvi adapter. If it is recognised ok you can then set the resolution from 1024 x 768 to the recommended amount for your new screen. The refresh rate is also important as some lcd screens only work at a certain level. There should be an auto switch on the monitor and if you press this it sets the display to optimum, - or should do.
Mar 21, 2008 | Computers & Internet
Monitor Problem
Well assuming you used the same video cable when you tested the monitor on the Asus PC you?re left with: - Physical problem with the Asus video card. - Asus video card configuration problem. - BIOS configuration problem - Possibly a problem with the DVI/VGA adaptor depending on the answer below. A couple of questions about the Asus before we start: - I?m not sure I understand how the DVI/VGA converter figures into this. Is your cable coming off the monitor DVI thus you need it to plug into the Asus VGA connector? If yes who is the manufacturer of the device and what model do you have? - Has the Asus worked in the past with another monitor or is this new? - What is its history/configuration?
Mar 11, 2007 | ASUS T2-AH1 Barebone
Computers & Internet Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
