Question about Beverage-Air Refrigerators
I have a Beverage-air sandwich/prep station. It seems to work ok but it contines to get to cold, when i turn it down it stays cold, fan blowing good and then over night it gets warm but the fan keeps blwing fine. Could be the thermostat or a pluged up drain line?? any suggestions.
    Guru:
  • 683 Answers
Clean the drain line, clean the condensor and if these dont work change the thermostat. let me know.
Posted on Mar 27, 2011
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
A/C fan blows enough air but temperature is niether hot or cold
CHECK YOUR PRESSURE SWITCH. IT IS ON YOUR EVAPORATOR.
Aug 04, 2009 | 1999 Cadillac DeVille
Salad prep cooler too cold I turn the t-stat up or down compressor still running I think the t-stat is bad don't you think?
It sounds like the thermostat is "stuck closed". Try unplugging the cooler, MAKE SURE ALL POWER HAS BEEN DISCONECTED. Remove thermostat cover with thermostat on it. Carefully pull one of the wires spade connectors off the thermostat. Insulate the end of the wire you disconected with electrical tape. Now plug the cooler back in. If the compressor stays off the thermostat is the problem. Let me know if that helps. I know of a common replacement cold controll for that unit:)
Apr 05, 2009 | True Refrigeration Mega Top Sandwich Salad...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Refrigerators Logo
447 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
