Question about Whirlpool LSR5132PQ Top Load Washer
Top half of agitator does not work - Whirlpool LSR5132PQ Top Load Washer
    Sergeant:
    Champion:
  • 202 Answers
Hi... you need to take the agittor apart and you also need to buy a part call "Dogs" it will show you how to instill them .. its really easy
Thanks
Posted on Mar 27, 2011
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Need to replace the agitator dogs and can't remove the mover from the bottom section
    Direct drive Whirlpool washing machines use a two piece agitator. In-between the two pieces there are cogs, sometimes referred to as "dogs," which will wear out. When the dogs start to wear, you will notice a clicking sound and the top agitator will not move as it should. When you learn how to replace the agitator dogs on a Whirlpool washing machine, you can have your Whirlpool working correctly again. Agitator dogs are available at appliance repair facilities.
    * 1
    Disconnect the Whirlpool washer from the wall outlet. Open the washer lid to access the agitator.
    * 2
    Insert a flathead screwdriver in the notch in the agitator cap. Twist the screwdriver to pop the agitator cap off of the agitator. If your model has an inner cap, remove the inner cap by pulling up on the handle and removing it from the agitator.
    * 3
    Use a socket wrench to remove the bolt in the center of the agitator. Most Whirlpool washers use a 7/16-inch bolt to secure the agitator.
    * 4
    Grab the bottom of the agitator with both hands and pull it straight up out of the wash tub. Do not have your face directly over the agitator. If it is stuck or pops up too quickly you could injure yourself.
    * 5
    Set the agitator on the floor and carefully place your feet on each side of the agitator. Grasp the top of the agitator and pull the top half of the agitator off of the bottom half. Turn the top half over to access the dogs.
    * 6
    Use needle nose pliers to pull the dogs out of the agitator. Install the replacement dogs into the agitator according to the specifications given the manufacturer.
    * 7
    Set the top half of the agitator back on to the bottom half. Make sure to align the two tabs together between the halves so that they will friction fit. Grab the bottom of the agitator and apply a thin coat of dishwashing detergent on the rubber gasket on the bottom using your finger.
    * 8
    Set the agitator back into the wash tub and secure it using the retaining bolt. If your model had an inner cap, set the inner cap back into the agitator until it snaps into place.
    * 9
    Place the top of the agitator into place and press down until it locks into place.
    Mar 21, 2011 | Whirlpool Washing Machines
    Agitator seems "broken" in half.
    You will need a set of adjatator dogs about 5.00 for a set..get them and we will show you how to replace.czerney@msn.com thanks for voting good luck.
    Mar 15, 2011 | Whirlpool Washing Machines
    Why wont the top portion of my agitator spin? It appears there are plastic gears within the top portion of the agitator. Can these be inexpensively replaced?
    Whirlpool, Roper, an Kenmore are the only brands with rebuild able agitators. Any other brand will need a replacement agitator. The parts are about 6 to 8 dollars.
    Here are some instructions I recently posted for someone else with a similar problem on an older whirlpool washer. If you need more specific instructions or the model you have is different let me know and I can look up the parts breakdown and give you step by step repair instructions.
    Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
    To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
    You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
    Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to separate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
    Good luck to You!!
    Jun 30, 2010 | Washing Machines
    The agitator tries to rotate, but instead jerks, but doesn't rotate in normal motion. It also makes a ratcheting snapping sound.
    Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to seperate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
    Good luck to You!!
    Jun 26, 2010 | Roper RAS8445KQ Top Load Washer
    The top half of the agitater does not work it just
    There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
    Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Agitator not working
    Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
    To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
    Please let me know if this helps you or if I can assist you further.
    Thanks
    Vic
    Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool top loader washer not agitating
    Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
    I hope this helps you.
    Vic
    Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Top half of agitator turns free (does not agitate)
    You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
    Good Luck!
    Feb 25, 2009 | Washing Machines
    The top half of the agitator (near the fabric softner comp) is skipping while it is in wash cycle
    yes the top half seperates from the bottom half inside the top half are 4 little parts called dogs. the part number is 241341. replace the dogs to fix it
    Nov 27, 2007 | Kenmore 22932 Top Load Washer
    Whirlpool LSR5132PQ Top Load Washer Logo
    Dan Webster
    Dan Webster
    Sal De
