Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
My moen vestige 7065csl made 3/4/2011 at 6.09 was installed by a pro and 3 hrs later the hot side supply blew out of the moen hanlde assembly. What should i do?
The faucet is defective . You will have to replace it with anew unit.
Posted on Mar 27, 2011
I have a moen 7065 and he handle has gotten so loose that you cant even select different water temps. How do I either tighten the handle or replace it?
hey Bob
I hope you still need help, but if not I will help you anyway.
The handle has a screw that goes into a lifting cam that turns the cartiage to hot and cold. I have seen more where the black ring is broken. To fine the part needed y9ou can do one of two thing. Call Moen and they will send you all the repair part for free. IF you can not get the repair done they will send you a new faucet for free.
Yuo cab up grade the faucet and they only charge you 55.00 Not bad for a new 200.00 plus faucet.
To replace the faucet just get a basin wrench and take the water tubes off and take lose all the nuts from below. Remove the old unit and install the new one. Oh replace the water supply tubes with new one. Not worth the risk of leaving the old one in and them leaking.
Have a great day
Rich
Sep 04, 2011 | Moen 7065 Vestige Single-Handle Kitchen...
Old moen vestiage kitchen faucet with current low water pressure. how do we fix?
First check aerator at end of spout unscrew and clean or replace,if that dosen't work turn off water and take cartridge out of handle assembly and check for any foreign matter, clean out reinstall,take care to remember position cartridge came out.
Jun 10, 2011 | Moen 7065 Vestige Single-Handle Kitchen...
When the lever on my Vestige faucet is turned to the hot side, it chatters and stops running when the hot water reaches it.
It sounds like you have a foreign body in the hot line,turn off water both cold and hot disassemble handle assembly including springs and washers slowly turn on hot water to see if object will flush out,if not disconnect hot water supply to faucet the turn on water supply slow ly to see if object is in supply line.If that dosen't work you may have to call plumber it may be in supply stop or below it and you need a professional to handle that.
Jun 10, 2011 | Moen 7065ORB Vestige Single-Handle Kitchen...
Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
When replacing handle it will not shut off water unless you push on top of tap.
You need to get the assembly back together properly there is a notch that needs to lock on cartridge area
Nov 07, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Can not figure out how to take it apart to replace leakey gasket
there is an allen key in the front of the handle.may be under where the hot and cold indicator is take that off and look to see if there is a hole.if so use an allen key to remove.
Jun 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
125 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
