Question about Endurance T3 Treadmill
I keep getting an ERR1 error on my T3 Endurance treadmill.
How do you fix the error 7
The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjuste
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Jul 13, 2014 | Endurance T3 Treadmill
Endex dcmd76
This sounds like a Bodysolid brand machine - you can contact the MFG directly at this number
TECHNICAL SUPPORT
Available M-F 9:00am to 5:00pm CST
Toll Free - 800-556-3113
Fax - 708-427-3598
Dec 03, 2013 | Endurance T3 Treadmill
How to test the test the board
very easy test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram attached.
God bless you
Jan 10, 2013 | Endurance T3 Treadmill
Dcmd67m digital signals to control the board
Hi, on the DCMD67M the motor run for short time (less than 1 sec) and stop and the error led (red) turn on, P1 displayed on the screen. What is the problem. Thanks
Feb 24, 2012 | Endurance T3 Treadmill
I am looking for spare parts or diagrams for control board DCMD67 for Endurance Tradmill runner 5. I am also looking for a new control board DCMD67. Thank you
Go to the 2 next web page:
1) this is free:
http://fitness.manulsonline.com
2) In this you must pay.
www.fitnessrepairparts.com
sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 28, 2011 | Endurance T3 Treadmill
When I turn on the treadmill, I get the "Err 7"
hi,
check the speed sensor near the motor pulley. if the sensor is open this problem can occur.
ok
Feb 06, 2011 | Endurance T3 Treadmill
I am looking for a cirit board for a endex DCMD67 for a bodyfit treadmill.
my DCMD67 circuit board keeps blowing the fuse or tripping fcl in house sw/bd.
Does not want to start, have had motor checked is ok, leads r ok. What to do?
Aug 12, 2010 | Endurance T3 Treadmill
Looking for a replacement endex pwm board
Call Body Solid @ 1-800-633-1227 ext 520 thats Parts and Tech support
May 15, 2010 | Endurance T3 Treadmill
How do I fix my Endurance Treadmill TF3i Err7 problem? I stopped during operation.
Unplug unit remove motor shroud check connections on lower board (incline board). I believe their is a 3 amp fuse in circuit check with multi meter to see if open replace fuse power up unit and if it blows the fuse then replace incline motor and if not, then use engine mode press stop then Incline + or - to force incline up to max incline then bring it down to 0 then turn off power then wait 10 seconds then hit power on then if error does not appear then hit start and resume using unit. If the procedure above does not activate unit then replace board.
Apr 15, 2010 | Endurance T3 Treadmill
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
Endurance T3 Treadmill Logo
43 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
