Question about Flirtomatic
I SIGN IN AND IT STARTS LOADING BUT THEN A LINE APPEARSS AND IT DSAIS IT IS READY AND IT IS NOT
I have been having this problem too i have emailed flirtomatic still waiting for a response tho
Posted on Mar 28, 2011
Sega genesis model 1 reset button stuck
YouTuber Challenge - Cracked Mega Drive Mobo - Let's Repair - Console Rescue
RetroGameTech
SubscribeSubscribedUnsubscribe58,03658K Loading...
Working...
Add to
Want to watch this again later?
Sign in to add this video to a playlist.
Sign in Share More
  • Report
Need to report the video?
  • Sign in to report inappropriate content.
    Sign in
  • Transcript
  • Statistics
29,661
717
Like this video?
Sign in to make your opinion count.
Sign in 718 6
Don't like this video?
Sign in 7 Loading...
Transcript The interactive transcript could not be loaded. Loading...
Rating is available when the video has been rented.
This feature is not available right now. Please try again later.
Published on May 30, 2013
Recently I was challenged by fellow YouTuber Daz, cojonesdeloro, to rescue his badly damaged Japanese SEGA Mega Drive. To add to the problems, his console was also what is sometimes referred to as an Asian PAL Mega Drive. Basically an originally Japanese console which has been "converted" (butchered
Apr 10, 2012 | Sega Genesis Console
I have a stihl hs 45 hedge trimmer, It starts but wont run, idles on choke than as soon as i swap it to run it stalls, i start on run it fires and than stalls. I have changed the spark plug and dioframes...
Hi, re -check the fuel pickup line. To do this you need to stretch it at the ribbed section as they are renouned for perishing in this area between the ribs, especially if it is a black line. The new type is green. Hope this helps, regards Phil.
Aug 08, 2011 | Garden
The damper pedal of my Roland digital piano is not functioning well. When I reset the adjuster as advised in the Manual, it works for a few hours, then stops working.
Find out if the adjuster is changing by itself. Put some tape on it to mark the position and check when it appearss to be out of adjustment. If it is unscrewing, you can get a Loctite product to seal the threads.
Jun 07, 2011 | Music
Error message,failed to open file:igo/480_272/loading.bmp exiting application. clarion map 670 sat nav,seems to be in constant loop trying to pair phone on bluetooth and above error appears when selecting...
The solution that worked for me is: in your iGO installation folder, open SYS.TXT file then find section [interface] next check if exist something like this: skin="ui_igo8" if not then add it, but you must first check in your DATA.ZIP file what is the name of the folder it can be ui_igo8_da, ui_igo8_pda... depending on version. After that iGO will load normally. One more thing, I've added this section at the end of SYS.TXT file [loading] show_statustext=1 show_progressbar=0 progressbar_x=62 progressbar_y=174 progressbar_bmp="loading_progressbar.bmp" ;you can disable this line bu putting ; sign at the beggining loading_bmp="loading.bmp" ;you can disable this line bu putting ; sign at the beggining
Hoppe this will help you!
Aug 04, 2010 | GPS
Disc drive not reading discs
replace the laser but first find out if you have a single or double len
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Signing in and Signing Out of Gtalk
it explains that slow in network processssssss
Apr 12, 2009 | Google Talk
Lexmark z640 series
Had same problem even after loading latest Vista driver. Found solution by disabling bidirectional printing flag on the port configuration menu. Hope this helps.
Oct 05, 2007 | Lexmark Z640 InkJet Printer
Flirtomatic Logo
150 people viewed this question
Top Flirtomatic Apps Experts
Bill Boyd
ray gallant
Are you a Flirtomatic App Expert? Answer questions, earn points and help others
