Question about Compaq Presario 700 470024-192 Notebook
Help Dear Sir my computer have sound and other driver but i can not use microphone ?
  • 304 Answers
Go into your control panel and click on sound devices. Make sure your line in is not muted. If you need more help feel free to ask.
Posted on Aug 04, 2008
Microphone Not Working!
If this is a microphone that connects to the 3.5 mm microphone jack, check that your microphone is connected to the Mic port (pink on the rear of a desktop). Make sure that the plug is fully seated. If you are using a front microphone jack on a desktop, try using the rear port (or vice versa). Next, if you have Windows, check that the audio input is set to Microphone, instead of Line In. (For Windows 7, this would be Start > Control Panel > Hardware and Sound > Manage Audio Devices (under Sound) and the recording tab.) Microphone should be your default device.
Next try uninstalling the audio driver and letting Windows reinstall the driver. Use the Device Manager (under Devices and Printers in the Hardware and Sound Control Panel). Expand the section labeled Sound, video and game controllers. Then right click on the Audio driver. Click on Uninstall then reboot the computer after the driver is removed. The correct driver should be reinstalled. (I believe that you do not have a separate driver for the microphone under Windows but you should make certain of that.) Check for driver updates as well. The Windows Update may list these as Optional updates.
If you have a USB microphone, try a different port. Also check for drivers from the manufacturer.
If you have an Apple or Unix OS, check for similar issues with the connection or drivers.
I hope this helps.
(who had a similar problem with Audacity recording on the line in port last month; I fixed the problem by uninstalling the audio driver and then reinstalling it. Then changing the Recording Source to Line In finished the fix. The driver got changed by a computer tune-up utility (registry cleaner).)
Apr 13, 2012 | Labtec Audio Players & Recorders
Sir myheadphone and microphone jack is not working
I am assuming that the internal speaker (and microphone if present) is/are working. If so then it could possibly be:
  • the jacks themselves; and/or
  • the wiring.
  • alternately, the plugs might just be inserted in the wrong jack, pls verify.
If the internal speakers work, then presumably the drivers/software are correctly installed making this a hardware problem. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 18, 2008 | Toshiba Satellite A135-S4527 Notebook
Sony vaio vgn-cs215j not work microphone let me help please.
This will happen if the Microphone in the Computer is not enabled or if the Audio Driver is not installed correctly.
To make sure that you have enabled the Microphone in the computer, please right click on the Sound icon on the System Tray (right corner of the taskbar). Then, select the "Recording Devices" option. This will open the Sound Properties window. In the Speaker/Headphones Properties window, click on the Levels tab. Then, on the Levels tab, next to Microphone , click on the speaker button to enable the microphone.After that click the OK button and close the open windows. This will enable the Microphone in the Computer.
If the issue still persists, you may need to re-install the Audio Driver in the computer to fix it.
To download the Audio Driver for the Computer, click here
Please download the file to a temporary folder in the Computer. After that, please open the folder where the file is downloaded and double click on it to begin the installation. Please follow the onscreen instructions to complete the installation process. After that, restart the Computer for the settings to take the effect. Re-installing the Audio Driver also fixes the issue with the Microphone. Hope this helps..
Good luck..!
Sep 12, 2010 | Sony VAIO VGN-CS215J/W Notebook
Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
I cannot hear any microphone playback
I cannot hear any microphone playback 2) Installing the driver software for it takes sound out of my computer my microphone seems to be fine because the green light comes on when i test it, but no playback in speaker when i record. I know im jus missing one little thing...can you help me?
Feb 08, 2010 | Tascam US-122 USB Audio/MIDI Interface...
Microphone not working on foxcomm ebot computer
U absolutely right...the problem is comes from driver also. First uninstall the drivers and reinstalll it with other drive(other than C:/). Also check the audio setting in right lower side of corner of your system, in which the audio properties the LINE IN mode is checked and the scroll bar of volume is full.
Thanks Good Luck
Aug 07, 2009 | Computers & Internet
Sir , I hv a compaq presario c700 product with KU764PA Product no . m using window vista OS. Sir I m not able to use My Inbuilt or extension Microphone..Watz the Problem..Plz sugges me wat to do ? I m not...
Go here to get the updated audio driver:
Once you are on that website, Click and download the file named: SP40762.EXE
When you have dowloaded to the file to your pc, double click on it and it will install the new drivers.
If this doesnt work it might be because your microphone is either turned off or turned down in the sound control section.
To get there:
Click start > Control Panel > Hardware and Sound > Sound
Then select the Recording Tab
Double click the microphone icon
On the page titled "General"
Device usage should be set to "use this device (enable)"
The next page to check is "levels"
Make sure "Microphone" has about 90 to 100 next to it
Click apply and ok to exit.
Reboot your pc and check for sound..
I hope that helps.
If it does, please rate me.
Jan 18, 2009 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 5920 webcam doesn't work
Sir after formatting webcam and microphone need thier driver so please install webcam and microphone driver. I sure your problem will be solve.Thanks
Jethu Singh
Nov 26, 2008 | Acer Aspire 5100 Notebook
Installing Microphone
Just plug it into the mic input on the sound card. All recent operating systems support it by default.
Jan 04, 2008 | Labtec Microphone Microphone
Sound!!! Help!!!
May be you should install you Sound Card installer again!
Apr 05, 2007 | IBM ThinkPad T42 Notebook
Compaq Presario 700 470024-192 Notebook Logo
18 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
