Question about Sony Vegas Movie Studio Platinum 9 for PC
An error occurred starting vegas pro error 0x80070002 Please help!
Tip
How to convert Flip video to Sony Vegas? Flip Video to Sony Vegas Converter...
Flip Video to Sony Vegas Converter makes it easy to import and edit Flip videos or HD movies in Vegas Pro. You can convert Flip camera video to Vegas WMV, AVI, MOV, MPG, etc with simple clicks for creating your next video or audio masterpiece in Vegas Pro. It will meet your needs whether you're a beginner, an experienced video maker, or a professional broadcast producer.
Two parts to introduce you "how to Import & Edit flip video with Sony Vegas".
Part one: FAQ about import flip video to Sony Vegas
Part two: Step by step on how to convert and import flip video to Sony Vegas.
Q1: Whenever I film a video with my Flip camera and bring it into Sony Vegas for editor, only the audio track appears with no vision. Do you have any suggestion?
Q2. I'm having trouble with Sony Vegas Pro 8, in that it won't recognize Flip SlideHD files at all. I get an error message saying "None of the files dropped on Vegas Pro could be opened". What should I do?
A: Sony Vegas as a great video editor compare to Windows Movie maker or Adobe premier doesn`t support all mp4 videos but supports some special mp4 (AVC video codec, AAC audio codec). Flip camera is not the standard MPEG-4 format (it is h.264 video codec, AAC audio codec). However, Flip video to Sony Vegas converter can give you a friendly hand-help you import flip video to Sony Vegas freely.
Step 1.Download Flip video to Sony Vegas converter and install.
Download Flip video to Sony Vegas converter and double click .exe to install. The trial version has no difference with the full version concerning video quality and effects."
Step 2.Add flip video into program
Click "Add video" button to add flip videos shot by Flip Mino, flip Ultra, Flip Mino HD, Flip Ultra HD or flip SlideHD camera into converter. It supports batch mode, so you can add many files as you like at one time.
Step 3.select output formats and destination
Hit the yellow fold button to select a destination on your PC for the converted files. In the drop down list of profiles, select WMV or MPG for Sony Vegas.
Step 4.clip and edit videos
Hit "Clip" button to trim videos into several parts that you need to convert. Click "Edit" button to crop and add effects.
Step 5.start conversion
Click "Start" button to start conversion to import flip video to Sony Vegas.
"Step 6.Load converted file to Sony Vegas
Load converted file into Sony Vegas.
Flip Video to Sony Vegas Converter is the one software I like best. Because it has a simple interface and keeps the confusing choices to a minimum. Moreover it offers the powerful option of converting as many files as you can throw at it in one batch.
on Sep 17, 2010 | Computers & Internet
Tip
Kodak Zi8 video to Sony Vegas Pro to Convert Kodak Zi8 video to Sony Vegas dv
Convert Kodak Zi8 Video to Sony Vegas Pro
Sony Vegas Pro may not look easy for the first sight, but it is indeed easier than other professional video editing applications such as the Final Cut Pro. And Sony Vegas Pro has nice and easy interface that is friendly to most users who have done video editing. It also allows you to import your media from various devices (including HD video) with 300 filters and special effects etc. All these make Sony Vegas Pro an excellent mobile video editing solution for video editors a on the go. If you are a Kodak Zi8 user and you want to edit Kodak Zi8 video on Sony Vegas Pro, you will need a Kodak video to Sony Vegas Pro converter to convert Kodak Zi8 video to Sony Vegas Pro supported formats – AVI, WMV or MP4.
Doremisoft Kodak Video Converter is the perfect application to for users who want to edit Kodak video on Sony Vegas Pro, whether they are using Kodak Zi8, Kodak Zi6 or Kodak Playsport. The following steps are how to use this Kodak Zi8 to Sony Vegas Pro converter to put Kodak video on Sony Vegas Pro:
Step 1: Add Kodak Videos
Click the "Add File" button on the upper left of the main interface to add the Kodak Zi8 videos you want to edit on Sony Vegas Pro.
Step 2: Select a Sony Vegas compatible format
Click on the small arrow on the right of the Profile field to open the preset "Profile" list, move your mouse cursor to "HD Video", and you see the preset formats to the right, scroll down, find and select "HD WMV Video". If your Zi8 videos were taken with a regular resolution, you can move your mouse cursor to "Common Video", scroll down to the bottom when you see the right list, and select "WMV Video".
Tip 1: Check the "Apply to all" option to the lower right of "Settings" so you can just select the Sony Vegas Pro format just once.
Tip 2: You can merge multiple files into one single file by selecting the files you want to merge and tick the "Merge into one file" option.
Step 3: Start to convert Kodak Zi8 video to Sonly Vegas Pro
When you are done the above steps ready for the conversion, click on the "Start" button on the low right of the main interface to start the conversion.
We recommend that you keep the "Open output folder when conversion finished" option selected, and the folder where the converted files are saved will be opened after the conversion. Then you can just import the converted files to Sony Vegas Pro and start editing them!
on Sep 01, 2010 | Computers & Internet
Epson stylus RX700 running on windows 7. Easy photo print will not launch. says fatal error occurred this program will terminate. Will not uninstall . I get error 5005:0x80070002 has occurred while running...
You can download the 0x80070002 from the following link. Make sure you download it will help you to fix this error. Optionally but not necessarily your machine should be clean of viruses and the Windows registry should be clean so that your PC remains healthy.
http://optimizingyourpc.com/repair/repairs.php?t202id=4672&c1=nume&t202kw=0x80070002
May 21, 2011 | Computers & Internet
When I open my sony vegas 9 project, it begins to load, but when it reaches 17% a pop up comes on with the following messege: "An error occured while loading the project back to chernowitz.veg. The file...
The file is most likely corrupt. I would recommend trying to reinstall Sony Vegas Pro if the problem persists. If you are trying to open a file within Sony Vegas Pro then i would recommend searching or asking for ways to fix the corrupted file format, however their are plenty of good file fixers online.
Aug 13, 2010 | Sony Vegas Pro 8 for PC (SVDVD8006)
Error An error occurred while loading the COM file
uninstalled the program, downloaded the latest trial version from Sony (25 da trial) and recovered the files without errors. I will try to repair my own version later.
Thanks for your reply.
Dec 19, 2009 | Sony Vegas Pro 8 for PC (SVDVD8006)
The system cannot find the file specified. (0x80070002)
Problem with 0x80070002 Error? Don't Worry - i'm here to help you fix it!
0x80070002 Errors are caused in one way or another by misconfigured system files.
So, If you got error 0x80070002 then there is a 94% chance that your computer has registry problems.
To Fix the problem you need to follow the steps below:
Step 1 - download and install RegCure Registry Scan for FREE.
NOTE: If the download link doesn't work you may need to Download it Directly from Regcure Site Here.
Step 2 - Click the Scan Button.
Step 3 - then click the Fix Button and you're done!
May 12, 2009 | Computers & Internet
Sony Vegas 8.0 Freezes when "Initializing Audio Engine"
Have you upgraded you Sound Drivers? Tried reinstalling Vegas? or Looked to see if a Patch or Update is available for Vegas?
Apr 04, 2009 | Sony Vegas Movie Studio Platinum 8
Local machine: installation failed Installation: Error: Action failed for file avgmfx86.sys: starting service.... Error 0x80070002
Could be bad media.
Try another install cd. If the same problem occurs, then the hard drive probably has bad sectors.
Feb 24, 2009 | Computers & Internet
Sony Vegas Movie Studio Platinum 9 for PC Logo
919 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
