Question about GE Refrigerators
Water leaking in 1997 GE refrigerator,top freezer type
    Guru:
  • 683 Answers
Usually if a refrigerator is holding water this means that the condensate from the freezer is not going down into the pan in the bottom, the water has to go somewhere so it ends up in your refrigerator. Find the drain line in the bottom and try some how to blow it out, if you can do this and clean the pan you should be ok.
Posted on Mar 27, 2011
Water leaking in refrigerator and floor of a 1997 GE top freezer type,model numberTBX22P1
As the only source of water is condensation or melting food, I would check to see if there is a drain hole at the bottom back of the fridge. This hole is to drain any water into the back of the machine where it evaporates. Use a pipe cleaner or similar to poke the muck through the hole and the water will drain away. Keep this hole clean every time you clean your fridge.
Mar 27, 2011 | GE Refrigerators
Water leaking on floor,it's a 1997 GE top freezer type
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
The freezer part of an GE refrigerator is leaking water
Probably the defrost drain is plugged. Flush out with hot water. A turkey marinade injector works pretty good.
Sep 24, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
How do you fix a water leak -the freezer is on top of the refrigerator and the water is leaking and coming from the back wall of the unit-
ck that the drain is in properly from the back side and that the line down the back is clear . you can force hot water through it with a turkey baster .. .. mm
Sep 01, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water leaking from freezer to refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | GE GTS22KBP Top Freezer Refrigerator
Defrost pan leaking
Water Running in Refrigerator from Freezer
heatman101
Apr 23, 2010 | GE GTS22KBP Top Freezer Refrigerator
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Water leaks into the freezer
under refrigerator you soposed to use hot water
Dec 22, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
