Question about Dryers
Fisher & Paykel DEIX2 (electric) dryer -- squeaking The F&P (4 years old) has a squaking that occurs when the drum is rotating. It was intermittent and is now continuous. I'm handy, but I'm not seeing the straightforward way to get to the area where the bearings are. Actually, I haven't pulled the unit out of the closet & really broken it down -- I've pulled the front off, though. I think the problem is in the side where the heat enters the drum, but would like your response to address both sides. I must warn people to get in the front every year or two and vacuum out the lint that gets past the filter. I was shocked.
  • rbrandom Mar 28, 2011
    What a cool design inside this model. Pull the top off -- two screws and free a wire, Pull the front panel off (2 screws). And you can then roll the entire drum-motor system forward onto the front and get at the motor-belt tensioner system. A little gentle force and you can take off the Y-shaped part off that holds both tensioner-idler rollers. They were both gummed up with burnt lubricant, and the "axles" were both abraded on one side, though they could both still be turned though with much difficulty.
    In my case, the entire problem was caused by the fact that the black closed-cell foam seal where exhaust and lint exits the system had broken away on one of the four sides. This allowed tons of lint and fine sand to settle all over the inside of my machine, including on the axles of those two idler-tensioner rollers. Add a little lint and you've got yourself some pretty sticky lubricant. Slow-turning, sticky and burnt makes for squeaking noises, I guess.
    Now I just need to get a new foam seal and maybe some lubricant for the bushings and shafts I've cleaned up (and smoothed with 800 grit). If there were a flat spot, I'd replace the assemblies, and might anyway if they're not too pricey.
    President:
  • 3,074 Answers
Drum roller/glides, idler arm, belt,or motor:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 27, 2011
Fisher paykel dryer DEIX2 squeaks when drum rotates
I've had the same issue with my FP washer, thanks for the tips!
Jan 17, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Why does the dryer squeak and grind as the drum turns?
Hi Karen
Your problem is that the drum rollers are in need of lubrication or replacement, that is what is making the noise you hear.
Please rate me
Bud
Nov 24, 2012 | Fisher and Paykel DEIX2 Electric Dryer
Fisher Paykel DEIX2 electric dryer parts list
If you need parts manual and to order parts go to www.coolblueworld.com Thats the official website.
Aug 31, 2012 | Fisher and Paykel Dryers
The model of my Fisher Paykel dryer is DEIX2 and it runs but doesn't get hot. It's four years old. Would it be cheaper to replace than repair? Thanks.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 04, 2011 | Fisher and Paykel Dryers
Looking for a parts list for a Fisher Paykel DEIX2 dryers
DEIX2 - one of the heat coils remains hot after dryer stops. I can see that it is still red (hot) after dryer is turned off. I need to unplug dryer for it to go off.
Oct 14, 2010 | Fisher and Paykel DEIX2 Electric Dryer
My dryer is a top loading Fisher and Paykel and it has started squeaking.
It could be bearing or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer won't turn. have cleaned & belt seems fine. electronics seem fine as well. when turn on only get a hum, nothing else. model fisher & paykel ED56AU. Any ideas? Thanks, Greg
the rollers (?) that turn the drum might need some lubrication ---- same thing happened to me and the tech removed the rollers (?? don't know the right word) and lubricated them ---- all working fine now
Jul 11, 2009 | Fisher DEIX2 Dryer
Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Nov 14, 2008 | Fisher DEIX2 Dryer
Fisher & Paykel DEIX2 Online repair manual?
I couldn't find one either. I would like to know what the different codes mean. Can anyone help?
Apr 01, 2008 | Fisher DEIX2 Dryer
Fisher-paykel electric dryer
Try turning it on while holding the door switch and give the drum a spin. If it starts you will need a motor if it does nothing then look for a solenoid.
Dec 20, 2007 | Fisher DEIX2 Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
