Picture freezes but sound is ok.what does that mean?
    Brigadier General:
  • 8,909 Answers
If it lock intermittantly, then check the signal from your aerial.
Posted on Mar 27, 2011
I have the Toshiba 72HM195 Rear Proj, sometimes when it comes on it is all green, restart it, and it is ok, now it is making a clicking soun d an d freezes
INDICATES a communication problem---set will not accept commands and this could mean a issue with the optical light engine.
May 14, 2012 | Televison & Video
Sharp lc32p50e, picture keeps freezing, sound ok. text hold symbol appears at same time as text freeze. any ideas?
try using the menu, and turn off the 'demo' mode ... this by default has a freeze setting .... hope that works
Feb 23, 2010 | Sharp LC-32P50E 32 in. LCD Television
I have a LG PC1DV Plazma and every now and then the picture will freeze, the sound continues on and you cannot change channels. the only way to un freeze is to turn off tv wait 30 sec then turn back on and...
Contact your LG dealer & have someone call to check the software version currently used by the TV. It may need updated as there is an issue for picture freeze, if this is ok there could be a problem with the signal strength of your signal, if this drops then it will also cause the picture to freeze, in which case you would need to have your aerial checked.
Dec 21, 2009 | LG Televison & Video
Intermittent sound/picture freeze when recording
this fault could be due to electrical interference ie freezer cutting in/out .just because your signal is strong dose not mean its interference free .check you analogue picture get it as good as you can with no ghosting. i also live in the southwest cornwall infact .aerials in lofts are not a good idea .i would mount it outside. by the way i am told that when the old analog channels are turned off the digital signal strength will be increased. good luck .farr64 [camborne cornwall]
Apr 29, 2009 | Televison & Video
NO PICTURE SOUND OK PICTURE COMS SLOWLY AFTER 1 OUR PHILIPS 50PF9966/12"
what do you mean..? be clear, so that many can help you...sir
Apr 27, 2009 | Computers & Internet
Picture freeze
dear sir.
her u bought a log. cam is latest it has some fitures like hi resulation and process with pictures so u need to do change cam resulation in camera setting then selacat low then try it's help u..:)
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | Logitech Webcam
My dvd player doesnt show picture but sound is good
Did you try replacing the video cable normally it is yellow right, Ok with the audio cable red and white, try to use them as video because theres sound meaning cable is ok, if the picture shows with red cable or white that means you have to change the video cable (yellow). hope it helps.
Nov 06, 2008 | Televison & Video
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
No picture
as sound is ok means power supply is ok. 1 check for filament if it is glowing means it is ok otherwise check for its supply. 2 check video and crt pins voltages 3 check for connector loose 4 luminance section in chroma ic. good luck
Sep 18, 2007 | Sony KV-27V10 27" TV
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
