Question about Microwave Ovens
How to remove the motor - Microwave Ovens
  • 2,510 Answers
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
Posted on Mar 27, 2011
Microwave mod# MMV4203DQ00 - turn table does not turn
Sounds like the motor is faulty.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | Maytag Microwave Ovens
Tip
How to change a microwave oven fan motor.
When your microwave makes loud noises, and they are eminating from the fan motor you will need to replace the motor. It no doubt has bad bushings. If not oiled periodically, and who does this, the motor will gall the bushings and make a loud screeching sound. Sometimes just oiling the motor after the sound starts will solve the problem, but most likely only temporarily. A permanent solution would be to replace the motor.
Unplug the unit. If your unit is not a freestanding unit and is mounted under the cabinet it will have to be removed from the cabinet first to continue. Usually this requires two people and the removal of two screws inside the cabinet above the microwave, tilting the unit down at the front and lifting the back of the unit off the mounting rail.
Remove all the screws from the rear of the unit case, perimeter and slide the cover off to the back. The motor should be visiable at this point. If it is not there could be a guard over it which should come off with one or two screws.
Go to http://www.repairclinic.com where you can get the new motor. They generally have parts for everything and at the best prices.
The mounting procedure should be obvious, either two or four screws. Remove and replace the motor. The motor wires should be spade lugs. Remove and replace one at a time to avoid any confusion.
Reassemble the unit by reversing the procedure listed above and remount under the cabinet if originally mounted under a cabinet and you should have a quiet running microwave.
hardrocko
on Apr 09, 2010 | Microwave Ovens
The glass plate inside will not rotate
Hope this helps.
Jan 01, 2011 | Thermador MBES Microwave Oven
The turntabel does not turn.
Sounds like the motor has failed.
Hope this helps.
Dec 31, 2010 | Sharp R-1870 Convection/Microwave Oven
Microwave makes noise when turning only in one direction
It sounds like the turntable motor is failing or the turntable requires its wheels cleaning. If it is the motor, it is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Replacing the motor is no big deal.
There is usually an inspection cover that can be removed on the underside of the cavity.
Remove the cover and remove the motor.
Replace with the same type and the reverse procedure will fix it.
You may however require a self tapping screw to affix the cover back on. A bit of a puzzle but not too difficult to work out!
Hope this helps.
Dec 29, 2010 | KitchenAid KCMS1555R Microwave Oven
Sharp microwave (R-959m) turntable not moving
Sounds like a new turntable motor is required.
Hope this helps.
Dec 28, 2010 | Sharp R-930AK Convection/Microwave Oven
Tray rotation motor does not work
Hope this helps.
Dec 19, 2010 | Microwave Ovens
Hi , in ur panasonic microwave glass tray is not revolving plz suggest what to do? thanks
Hope this helps.
Nov 04, 2010 | Panasonic Microwave Ovens
Model is JES1451. Turntable won't turn. I removed the cover and the motor and the shaft appears to be broken. How do I remove the broken shaft and replace the motor?
Hi the shaft should just pull up, to remove the motor you will need to turn the oven onto it side, you will see a cover at the bottom of the machine to remove this you will probably need to cut through three of the tabs, you can then gain access to the two screws securing the motor.
When replacing the cover turn it over and fix using the spare self tapping screw to be found in the base near to the cover you just removed.
Hope this helps
Jan 05, 2010 | GE JES1456 Microwave Oven
RVM1435 Turntable not working
The turntable motor can be replaced by following these simple steps:
1. UNPLUG the microwave before servicing.
2. Locate and remove the screws around the perimeter of the bottom panel of the microwave (located UNDER the microwave bottom).
3. With the screws removed the panel will open, exposing the turntable motor. Remove the glass tray and reach inside the oven cavity and grasp the turntable spindle. Pull straight up to remove it from the motor shaft.
4. With the spindle removed, disconnect the motor connector plug and mounting screws.
5. Insert new motor and reinstall everything using the steps provided in reverse order.
If you have any questions, please let me know. I hope this helps you.
NOTE: If this microwave is mounted, this repair can be performed without uninstalling the oven.
Aug 15, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
