I get message on the desktop saying screen resolution slow and set it to correct resolution.
  • 122 Answers
Hello, go to youe screen right click on the blank side and look for resolution and click on it set to the right size you want.( This is if you are using windows 7).
Posted on Mar 27, 2011
Message on monitor says " no analog signal".
If you are getting no post display on boot up (dell spash screen, and windows loading screen):
First step is to plug a different monitor into the computer. If this works you most likely have a bad monitor. If not then it is a hardware issue with the video card on the computer.
If you getting the post screen then you may have your resolution set to high, boot in safe mode (F8 on the key board right after the post screen) and chose safe mode. once windows comes up, right click the back ground and chose a lower resolution setting.
Hope this helps
Oct 17, 2011 | Dell OptiPlex GX620 PC Desktop
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
The monitor is giving a zoomed in view . its not giving the full view of the desktop screen rather a section of it is zoomed in . there are no settings to zoom out .??
ur setting may be set to low resolution...
try doing this
go to Desktop/right click/properties/Settings/Screen Resolution/
What do u c...what's the resolution there...800x600...
if the slider(pointer) is active use it to increase it to say 1024x768, 1152x864, 1280x1024 etc.
use the correct resolution....as too much of resolution will make ur monitor un-viewable...
also try if ur monitor has some press button on them to make changes to the correct setting/zooming of the screen image...
Dec 24, 2009 | Samsung Syncmaster 2033SW Monitor
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
After restarting for an automatic update my desktop was in a "default" arrangement and the resolution was changed. I attempted to change it back but must have set it to the wrong res, cus the screen went...
Yes video drivers need to be updated then go back where you went to change the resolution and click keep this resolution I think you mistakenly told not to accept it this happens.
Please leave postive feedback and ratings today
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 15, 2009 | Samsung SyncMaster 512N 15" Flat Panel LCD...
My monitor has a message floating up and down saying not optimum mode recommended mode 1280x1024 60Hz what do i do
dear dalton,
1.right click on desktop.select properties and click it.
2.then select settings tab on top.
3.there u can see the screen resolution slider bar. there u can select the optimum mode for ur monitor.
thanks,
Sep 30, 2008 | Computers & Internet
Changed screen resolution. Now when turning on computer and monitor a message appears " is screen resolution correct? If any key is touched the monitor goes to standby.
try to boot on safe mode, by pressing f8 while booting then choose safe mode,
while in safe mode you can set the resolution back to its default .
Sep 11, 2008 | Computers & Internet
Display monitor
Assuming that there is no hardware fault, this is indicative that your PC's Screen Resolution and/or Screen Refresh Rate are higher than what the monitor can display.
To correct, start your PC in Safe Mode, go to Display Properties (right click on any clear area of your desktop, click on Properties, click on Settings tab, move Screen resolution towards left or 800 X 600 and lower Color quality to 16 bit) and lower down all settings (including Advanced/Monitor/Screen refresh Rate). Reboot.
Once in Normal Mode, do the same again and increase settings one step at a time and click OK/Apply. In the event that the display disappears again, hit escape and/or revert back to last known good setting(s).
Hope this be of help.idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 19, 2008 | ViewSonic (CO21)
Computers & Internet Logo
27 people viewed this question
Alun Cox
David Payne
David Payne
