Question about Samsung Televison & Video
Have a Samsung HP-S4253. For past couple weeks if it is turned off it takes multiple attempts to get the picture to turn on. I turn on and sound comes up but no picture, so I turn off and on 10-20 times until picture comes up. Still has great picture when on.
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 27, 2011
My Samsung HD-S4253 42" plasma TV will not turn
did you ever find a solution? Mine is doing the same as of yesterday
Richard prasadram3@yahoo.com
Sep 11, 2011 | Samsung HP-S4253 Television
Have Plasma TV HP-S4253 Have sound but no picture (first turn on picture comes on for 5 seconds) Is this worth fixing?
it may be the lamp in the screen has gone bad the tv is worth replecing more than fixing cuause a screen costs almost as much as a tv
Jan 02, 2011 | Samsung Televison & Video
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
My plasma tv has sound but picture turns black after on for 30 seconds
Power supply problems, Will need to be taken it in for service. Usually around a $200 to 300 dollar repair if you take it in.
Blessings,
A/V Media Tech Guy
Nov 23, 2009 | Samsung HP-S4253 Television
Samsung HD Plasmhp-s4253 has developed some color issues. The
I had this same problem and one of my component cables was slightly unseated. Slight push back in and got all my wonderful blues back!! Thanks tvtek for this suggestion!
Nov 12, 2009 | Samsung HP-S4253 Television
Green and red pixel snow
This change the voltage doesn't sound right to me. You What voltage is someone telling you to change ? You should just have to plug into the wall and turn on and get a nice picture. I think something inside has failed and that is why you have the snow.
Sounds funny to me, I would have a technician look at it.
Apr 04, 2009 | Samsung HP-S4253 Television
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Samsung HP-S4253 black screen, with sound
Its the broadcasting company and there "new technology" Have had an over the air box to get local HD channels and lost my PBS station, turned out to be a new signal incompatibility. The same is with my HP-S4253. Must not have the latest SW to process the new signals
Feb 19, 2008 | Samsung HP-S4253 Television
Open Questions:
Televison & Video Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
