Question about Brother MFC 7840W Printer
I HAVE A BROTHER MFC-7840W PRINTER. I AM TRYING TO SET UP THE WIRELESS NETWORK, AFTER ENTERING THE WEP KEY IT ASKS ME TO PRESS "ENTER". THERE IS NO ENTER KEY. IS THERE ANOTHER BUTTON TO PUSH?
  • 1,591 Answers
Whenever it says "Enter" read this as "OK"
Why the printer doesn't just say "press OK" I couldn't tell you.
Posted on Mar 27, 2011
When setting up networking on the printer the wep code will not enter when I select ok whats wrong
Your code must be wrong, double check your password. If you have set it before , please reset the nertwork settings first.
Oct 18, 2014 | Brother MFC-7840W Multifunction Laser...
Enter key for brother mfc 8870
The 'OK' button is the enter button for data entry purposes.
When in settings pressing ok will accept any setting you have changed.
Sep 05, 2014 | Brother MFC-8870dw Wireless Multifunction...
Brother mfc-7840W not picking up wireless IP address
It is common, mainly because the MFC connection is lost to your PC. Are you able to print or scan from another wireless PC that you have? If yes, contact your network admin or router oem. If no, reset network card. Run the Setup Wireless Wizard. Make sure you have router info such as SSID, Network Security Key, Authentication Method (Open, Shared, WPA/WPA2-PSK), Encryption (None, WEP, AES, TKIP). Enter those info, it must be CASE SENSITIVE. Just in case you dont know your router info, contact your router oem.
For Advanced Users.1. Click your Wireless Icon at Task Tray2. Right-Click your Wireless Network Name3. Select Properties4. Go to Wireless Security Settings5. Take note of the settings that you have there and enter it again on your MFC
Goodluck! If you still need more assistance. Call us 1-877-Brother. :)
Jan 03, 2012 | Brother MFC 7840W Printer
Brother MFC-7840w wireless printer won't connect to network. I have searched a ton of solutions on the web and have had no luck. I have several devices connected to my wireless network, but just...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
Make certain that you have the latest drivers from Brother by clicking on the following link: Brother Driver Downloads
Open Control Panel and click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
This should have you up and running.
All the best
Ben
Jun 18, 2011 | Brother MFC 7840W Printer
How do I enter the number "0" when entering a password for WLAN? I'm trying to connect to a WLAN using WPA encryption with a password including the number "0" but when pressing "0" it shows up as a star...
Brother's documentation is non-intuitive. Pressing the ' 0 ' key shows a ' * ', but it actually is accepted as a 0 and moves to the next character entry position. Just take it on faith that it enters a 0 when it shows * when entering the wireless key.
May 28, 2010 | Brother MFC 7840W Printer
MFC-7840W Printer: need tp set the wireless setting, lost the instruc...
To setup your Brother MFC-7840W on a wireless network do the following:
Press Menu.
Scroll down to #5 LAN and hit OK
In the LAN submenu, scroll down to 2. WLAN and hit OK.
In the WLAN submenu select 2. Setup Wizard.
(The printer will search for the SSID of your network. If you are presented with multiple networks, select yours and hit OK.)
Depending whether you have setup a network key on your wireless network, you will have to choose the type of connection. Your options will be Open System, Shared key, and WPA/WPA2-PSK.
If you have a Shared Key or WPA/WPA2-PSK network, then you willhave to enter the key to connect. Open Key does not use a key to connect.
So for instance, if you selected WPA2-PSK you will then be asked to enter your passphrase key to connect to your wireless network.
May 16, 2010 | Brother MFC 7840W Printer
Will a Brother MFC-7840W wireless printer work with a Netgear RangeMax Next Wireless Router (WNR854T)? My Toshiba laptop setup was a breeze with this router. I'm having trouble connecting the printer to...
When entering the wep key, after each character is entered push the right arrow. If the same character repeats itself it will overwrite the other if you dont.
Dec 10, 2009 | Brother MFC 7840W Printer
Brother MFC-7840W Printerwill only give me Scan To FTP option now
i had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Jan 18, 2009 | Brother MFC 7840W Printer
Ignore the instructions that come with the printer, choose Open System, then choose WEP, enter, and it hooks up. Thanks to the above posters for this solution.
Aug 12, 2008 | Brother MFC 7840W Printer
Brother MFC 7840W Printer Logo
1,328 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
