Question about Dishwashers
When opening and closing our kenmore elite dishwasher the door springs make an awful creaking sound, how can this be fixed
    President:
  • 1,489 Answers
Liberally lubricate hinges, spring and any other relavant parts with WD-40.
Charlie
Posted on Mar 27, 2011
How do I repair the spring that holds dishwasher door?
The door spring can be seen on the side of the frame just below the bottom of the door. If the spring has just popped off you can put it back easily when the door is open. If the spring has become weak, you can get a new one from an appliance parts store or online.
Jun 10, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwasher model 665.16493300 door falls to floor when opening
Door springs are located at the left and right side of the door bottom. You will have to pull the unit a few inches from the installed location to see them. If broken, replace. If one slipped off, reattach.
Mar 09, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher elite door opens too fast, broken spring?
Could be that, the spring may have unhooked or it could be a defective damper connected to the door. Remove the side panels and check the operation of the door mechanism. (This will probably require the removal of the rear panel to gain access to the necessary fastners).
Jan 21, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Right hand door spring appears to be shot -
It sounds like the spring is dislocated. May just need putting bck in the right place.
May 02, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Noisy Door
The noise is comming from the counter balance spring and rope system. You will need to pull the unit out from the counter and then you will see the springs. You will have one on each side near the bottom of the floor. Sometimes a lil grease or PAM spray will quiet them down.
Good Luck!
Feb 14, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Door won't open slowly
Hi barrianne,
I'm Harvey the Master Plumber.
You're asking: On my Kenmore elite, on opening, suddenly the door just slams to the bottom without the gradual opening that it had before. And you have to really close it -- previously it would stay ajar 2 or 3 inches but now it will open all the way. Whatever was holding the door up and not in the down position is now kerplooie. Any suggestions?
You're not alone! This is very common. It is usually easy to repair if you have the technical skill and tools to remove the d/w to allow access to the springs on each side and properly reinstall. I don't recomend it to the average homeowner.You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
