Question about Hotpoint Aquarius WMA56 Front Load Washer
How to turn off the child lock - Hotpoint Aquarius WMA56 Front Load Washer
    Brigadier General:
  • 6,277 Answers
Press and hold the child lock button for more that 3 seconds- that should cure it ;-0)
Cheers,
John C
Posted on Mar 27, 2011
The child lock on my smart drum lg washing machine is on how doi turn it off please
To TURN OFF CHILD LOCK on your LG washer, press and hold the CHILD LOCK button for 3 to 5 seconds. The washer should now have CHILD LOCK mode DISABLED and all buttons will function properly.
PLEASE NOTE: ON other newer LG front load washing machines hold the PREWASH/CHILD LOCK button for 3 to 5 seconds to turn CHILD LOCK OFF.
Jul 28, 2018 | LG Washing Machines
How to turn off the child lock on a dryer
This information is from the manual:
Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
May 27, 2014 | LG DLE2514 Electric Dryer
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
How to remove child lock
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code
Apr 26, 2012 | Televison & Video
Child lock is stuck on and athe dryer will not turn on. How do yoiu turn off the child lock?
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows. To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is displayed on the status window. To unlock Child Lock, press and hold Rack Dry for 3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 03, 2011 | LG DLG5988 Gas Dryer
My TV is on child lock how do I unlock please
  1. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
  2. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
  3. Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Read more: How to Unlock the Child Lock on a TV ' eHow.com http://www.ehow.com/how_4510749_unlock-child-lock-tv.html#ixzz12VdKs6Bt
Oct 16, 2010 | Televison & Video
How do you turn off the child lock on a RinnaiRCE229H natural gas Heater?
Basically hold in the child lock button for two seconds. If the child lock was activated and you then turned the unit offt the child lock remains set and will stop you turning the unit on. To deactivate, make sure you have the power lead pluggeed in and turned on. Before you depress the ON/OFFbutton, hold in the child lock button for two seconds. This will deactivate the child lock and allow you to turn the heater on.
Here is a link to a users manual, check out page 11.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/150.pdf
Aug 15, 2010 | Heating & Cooling
How to remove child lock on rear doors?
Show me how to take the safety child lock off switch also I need a picture of this location on the door
Jul 20, 2010 | 2008 Chrysler Town & Country
How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit....
ur problem will be solved.. rate me!!!!
thank u
Apr 10, 2009 | Televison & Video
Hotpoint Aquarius WMA56 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
