Question about Cell Phones
  • Anonymous Mar 06, 2009
    the device is not found when i try to search for it on my phone
    device is not found when i search for the device
    An expert whose answer gotĀ voted for 100 times.
  • 208 Answers
You need to switch on the bluetooth in both the mobiles and keep it as close as possible. If it cannot detect the device there must be some problem with the name assigned for the mobile.
Posted on Oct 05, 2010
How to pair my sprint slx-800 to my android phone
You should search for this topic and answers, First.
Try 0000 that's the default for all bluetooth accessories.
If that doesn't work, here is generic instructions:
Paring a Bluetooth Handset with Android phone:
Now that you have your headset in pairing mode, proceed to pair it with your phone:
From the home screen, press the Menu key and then select Settings.
Tap the "Bluetooth" toggle to ON.
Tap Bluetooth to scan for devices.
NOTE: You will automatically be connected to an available saved device when Bluetooth is turned on.
Tap one to connect.
NOTE: A security code may be required. (Try 0000)
The Bluetooth connected icon will be displayed in the notification bar, and the device will now be labeled as Connected.
Place calls using the Bluetooth headset
Ensure the Bluetooth headset is paired with the handset.
Place the Bluetooth headset over your ear.
Dial the desired the phone number on your phone, and then tap Call.
Receive calls using the Bluetooth headset
Press the Call button on the Bluetooth headset when a call is received.
Aug 20, 2015 | Sprint Cell Phones
How to pair the bluetooth of samsung SGH-T429
Hy gcahig, follow the instruction (note :if my solution was helpful please rate the answer) :STEP 1. Locate the Bluetooth Settings Menu
To pair the handset with a Bluetooth Device follow the steps below:
  1. From the standby screen, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Bluetooth (6)
STEP 2. Activate Bluetooth and Search for Device
  1. Select My Devices (2)
  2. Search for the Bluetooth device by pressing the left soft key for Select
  3. Press the left soft key for Yes to Activate Bluetooth and start the search
STEP 3. Pair with Selected Device
  1. Highlight the desired Bluetooth Device, using the navigation keys, then press the left soft key for Select
  2. Enter the Passkey "0000" then press the left soft key for Select
  3. The handset will display a brief message stating connecting followed by connected
  4. After being successfully connected you will return to the "My Devices" screen.
Source :
Jul 13, 2012 | Samsung Cell Phones
Today I bought a Bluetooth handset a brand called Bluedio module number N65. I unable to pair this device with my Dell latitude E6410 which is running Windows 7. But its possible to pair with my Nokia E72,...
when pairing any device you must set the bluetooth activate on active devices and then in the settings select search for active devices or pair a new device
(this may vary depending on the device you are pairing)
hope this helps
Jun 04, 2011 | Computers & Internet
My friend gave me his bluetooth but i need the pin to connect it to my phone and i cant get it .how can I pair it to my phone without using a pin or making a new pin?
The pin or the passkey is "0000". To pair the SGH-T749 (Highlight) handset with a Bluetooth Device follow the steps below:
  1. Place the Bluetooth device in discoverable mode
  2. From the standby screen, press on Menu
  3. Press on Settings
  4. Press on Bluetooth
  5. Search for the Bluetooth device by pressing on Search, located at the bottom
  6. Press on Yes to Activate Bluetooth and start the search
  7. Press on the desired Bluetooth Device (if not shown press on the left or right arrows until displayed)
  8. If prompted, press the Passkey "0000" then press on OK
  9. You will get a brief message stating connecting followed by connected, if prompted press OK again
Note: The first time you try to pair with another handset, you and the owner of the other handset must enter the same PIN. Once the handsets have been paired, you will not need to use the PIN again.
Mar 30, 2011 | Samsung OEM Travel Wall Charger for...
Can u please tell where to find blue tooth on nokia c3110
To use the Bluetooth function on your handset, you will need to select Menu>Settings>Connectivity>Bluetooth. Then you will need to activate the feature. To do this, select ON to activate it. Then you will need to make your handset visible, to do this you will select visibility, or my phone's visibility, to the ON position. This will enable other Bluetooth users to connect with your handset for sharing. Note: You will have to accept when someone is trying to connect to your handset via Bluetooth if you wish to accept. To pair with a device, you will simply select search for device, and it will pick up any Bluetooth devices in the area. Please note that your device is Bluetooth A2DP capable, which means that you can use any Bluetooth technology equipnent that is A2DP and below, it is backward compatible. You will not be able to pair if the Bluetooth technology is greater than A2DP. You also have the ability to name your handset, to do this simply select My phone's name, and choose the name that you desire the handset to have. This will make it easier for someone to pair with you if you choose to share files.
Mar 20, 2011 | Nokia 3110 Cellular Phone
Handset on Mitel 5340 IP phone with bluetooth has no dial tone but has dial tone on speaker. Bluetooth signal is fine. Help.
Are you referring to the Mitel Cordless handset or headset? The handset and headset must be paired to the module on the back of the phone. Press and hold the button until the display indicates pairing. Then press the Answer button on the handset or headset.
Jan 07, 2011 | Mitel 5340 IP Phone
I need pass code to activate my wep450 ear piece
The passcode for this and it never changes is 0000 you would input this into your handset for pairing, let me know if you still have trouble, Thanks for using
Aug 03, 2010 | Samsung WEP450 Bluetooth Headset - Retail...
How do you pair this device with a mobile phone ?
Hi simon,
To pair the bluetooth headset to your mobile , you have to make your headset in visible mode, to do this
  • Press and hold the power button of the headset for 10 seconds, you should see LED flashing in the headset..
  • Now search for the bluetooth device from your Handset..
  • You could see a speaker symbol in the searched devices in your handset...
  • Just select that device and when it asks for the pair code provide 0000 by default of refer you Bluetooth headset manual.... After this you should be getting connected to the headset
Jul 03, 2009 | Nokia BH-300 Wireless Headset
Forgot how to par my bluetooth PLT 510 to my Palm Centro
To pair with a Bluetooth device:
  1. Make sure the device's Bluetooth radio is on.
  2. Set the handset's Bluetooth discover mode to On.
  3. Select the appropriate Bluetooth accessory.
  4. Enter your PIN number.
Once a Bluetooth accessory has been paired with the device, it can be used with the device, without the need for re-pairing, assuming the appropriate profile exists for the required service.
Sep 16, 2008 | Plantronics Lands Phones
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Cell Phones Logo
61 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
