Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
Ge ice maker is leaking water from the fill tube extension. water freezes and pushes tube out of refrigerator wall.
  • 107 Answers
Your water valve is not sealing closed completely and allows drips of water to seep through and freeze inside the fill tube. Either your water valve is bad or you have low water pressure to the fridge. Turn the water supply off, disconnect from the fridge's water valve, and turn supply back on and run it into a bucket. Should be pretty strong flow. If its weak the fridge ain't your problem.
Posted on Sep 21, 2011
My ge ice maker not making ice and no water coming in at the top to fill water inlet was leaking so bought new one and changed it and still no water to ice maker but the water is working to fill a gla
there are two valves,one for ice maker and other for dispensenser,also check the tube that filles the ice maker and make sure that it's not frozen,sometimes the tube freezes but this is still caused from bad water valve
Oct 10, 2014 | GE Refrigerators
I have a hotpoint refrigerator freezer that works fine except i am having issues with the ice maker. The tube carrying the water to the ice maker goes through a support cup. Water has started freezing in...
Make sure tube is pushed all the way into back wall tight.Then make sure tube angles downward so water completely drains. This is a goofy GE problem.
Aug 16, 2011 | GE Refrigerators
Water does not stop pouring from water/ice dispenser. Door-to-door GE Profile Refrigerator Model TFX22PPDACC. How to troubleshoot the problem? Or what part need to be replaced?
With the water running tube/pipe is cracked in between or its got loose from its fitting.First inspect the line for this problem.The tube from which water passes, one end is connected to the water valve at the back base of refrigerator.And then from valve two tube runs.One tube is for water dispenser and another tube is for ice chamber filling.Follow that tube from back of the refrigerator.The water dispenser tube That passes through the freezer door also.And the ice maker tube.That connects to the back of ice maker tray.The water fills in the tray.See if that tube is got loose and its not throwing water out instead of ice maker tray.Many a times this happens.--- May be you need to remove the ice maker to get exact location for tube setting and position.----------- But if tubes from water and ice dispenser sections are fitted properly and then there can be crack in the tube.------------But if tubes checked out ok then other possibility can be faulty water fill grommet.------- The grommet is cracked.And that is causing the leak.--------- Go to the back of the unit and remove the cover at the lower right of the unit. This is where the water line goes into your unit. Remove the water line at the solinoid that goes to your ice maker . This will allow you enough slack to remove the old water fill tube and replace it with the new one.
You need to push the white retainers in to release the tubeing from the solenoids.
The part you need is called fill tube grommet.It has to be removed and replaced.The tube is connected to the grommet. Click this link below for more help:---http://technoanswers.blogspot.com/2011/06/how-to-remove-ice-maker-fill-tube-from.html
------------ The other possibility for this leak, is water valve.The water valve close and open.When its open, it lets water to the tube.When it closes it stops water.But if the valve is not closing then it will let the water to enter non stop, slowly --- slowly the inside tube getw over filled and then starts leaking.------------ The water valve is not required as per the problem.But if after doing all the repairing, still the same problem, noticed then water valve is required.Because is water valve is not closing properly, then it leaks some water, (drop by drop) and this can cause water to collect in the grommet and this gets formed into ice and the same leaking repeats.---------but at present dont buy water valve.Just keep an eye on this same problem.sometimes leaking will start after few days.In that case also replace water vale.------- Now for other parts, that are extension hose,icemaker tube and clamp.Out of this you will require clamps, sometimes while removing old tube the clamp gets cracked.you can buy this.The extension hose is required if the tube is getting short or actual hose is cracked in between.i dont think you will require extension hose at present.And for ice maker tube.This tube can also be cracked and cause leak.this tubes by time gets bit swollen and loose its grip.Its actually not required.But if you still replace it, that it will be good.--------so you can order clamp and icemaker tube with the grommet part.----------- The parts which you want to order, this is direct link for parts:-- 1. Dual Inlet Water Valve------------ (http://www.partselect.com/PS901314-GE-WR57X10051-Dual-Inlet-Water-Valve.htm)
2. Icemaker Water Line ----------
(http://www.partselect.com/PS299643-GE-WR2X9245-Icemaker-Water-Line.htm)
3. Icemaker Fill Hose Extension ----------
(http://www.partselect.com/PS298725-GE-WR2X7927-Icemaker-Fill-Hose-Extension.htm)
A fill tube clamp for the fill tube grommet----------------
(http://www.partselect.com/PS297951-GE-WR2X4754-Fill-Tube-Clamp.htm) ----------- This will help.Thanks.Helpmech.
Jun 16, 2011 | Refrigerators
Tube feeding ice maker comes off
Good day,
Common problem. Remove ice maker, and make sure tube fits all the way to the rear and seats properly.
Then reinstall ice maker and telescope front part of file tube until it fits into ice ice maker properly. (retaining clip in place).
For the cost, a new fill tube makes sense. Also.........
If the water valve leaks slightly after shutting off during a fill cycle, a plug of ice will build up inside the the fill tube, pushing it off on the next fill cycle. Requires installing a new water valve.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Apr 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezing food and leaking water
faulty water valve will cause the issues with the ice maker fill tube , possible faulty air damper will cause the fridge to get too cold
Jan 07, 2008 | GE PSS25NGM Side by Side Refrigerator
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
405 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
