Question about Iron Horse Warrior Elite
How do i adjust the rear shock (rock shox bar)
    Guru:
  • 347 Answers
This is a very basic Air Shock, the only way to "tune" more than adjust is by changing the air pressure, either by releasing some or adding some. To add you need a shock pump. you can get these at most bike shops that sell mountain bikes.
Posted on Mar 29, 2011
I want to know if i can repair the showa rear shock absorber
hi, there are companies that repaire shox, but wether they can get the parts for showa i dont know, would it be cost affective? there are better shox out there on the market. hi are you uk based, try calling ktech suspension i know they do showa fork spare parts.
Parts Department 01283 559 000
regards
paul
Feb 03, 2011 | Honda Vf 1000 F Motorcycles
Riding rough sounds like shocks.. but I dont think gran am has shocks.. could it be the moter mount that would make it ride rough and when you turn the stering wheel back and forth while driving it sways.
All cars have shocks and/or struts. Grand am has front struts and either rear struts or shocks. When these are worn, the ride would be rough. If a motor mount was bad, you may feel rocking or visually see the motor wiggle back and forth when you press and release the accelerator pedal. Motor mounts won't affect handling. Either shocks/struts, sway bar, stabalizer bar or links are the common cause
Dec 31, 2010 | 2002 Pontiac Grand Am
What's a "hardtail"? What's "full suspension"?
A "hardtail" is a mountain bike that has a front suspension fork (like the one on the right) and no shock absorber in the back. Good hardtails are light, fast and responsive, and because of this they are good for climbing.
Even the cheapest mountain bikes these days tend to have suspension forks. That's not necessarily a good thing, since most of the forks on cheap bikes are of poor quality and will probably need replacing before too long. The cheapest forks also tend to be sold only on new bikes, and not separately. Find out the make and model of the fork, and search around on the web for it. The price will give you an indication of the fork quality.
Most decent bikes are sold with Rock Shox, Manitou, or Marzocchi. Marzocchi has been making forks longer than anyone and has probably the best reputation, but they tend to be expensive so you won't find them on anything but expensive bikes. Rock Shox and Manitou make lower-end (but reasonably good) forks. Other reputable brands such as Fox and Suntour make forks that may very well provide a good service life, but are not as well known for mountain bike forks. Replacement forks can be found at very low prices during sales and clearance events, so they can be upgraded later (sometimes at a bargain price). A "full suspension" bike has the front suspension fork and a rear suspension (like the bike on the right). These are highly recommended if you ride in a lot of rocks, as the rear suspension allows you to glide over rough terrain. They're also good for big jumps. The rear shock adds some complexity to the bike, and a good bit more weight at any give price point, plus there'll be a bit more maintenance. Plus, you'll pay a few hundred dollars more than a hardtail for a bike of otherwise equal components. Depending on your terrain, it might be worth it; riding a hardtail in big rocks can be brutal.
Dec 16, 2010 | Cycling
Have a 1996 explorer sport with 200k. Daughter said the truck started to drive "like a boat tossing and turning" at highway speed. Front end was rebuilt not long ago. shocks seems fine and...
Yes this sounds like A sway bar condition and yes you can Replace just the links and bushings. I would not replace the sway bar its self unless that is infact what broke. I hope this helps you out. i would appreciate it if you would rate me.
thank you
Aaron
Nov 15, 2010 | 1996 Ford Explorer
How do I buy a complete new set of bushings for the conection shock/frame on an iron horse mkiii ?
Hi dan dont know if this is any good but try MOJO online in uk i got float and rock shox bushings from them
Mar 13, 2010 | Iron Horse 2008 MKIII Elite
Rocks sideways when driving, feel like you are on a boat
Have the shocks/struts ever been replaced? The rocking is normally caused by worn out shocks and/or sway bar bushings. When the shocks go, you normally will experience a rollercoaster type up and down motion when you hit bumps (the springs are bouncing and the shocks are not dampening/rebounding properly). If you do not have this up and down rocking, but just sideways, check your front and rear sway bar bushings for wear or damage to where they connect to the frame. If the mount has broken or come loose, it will not prevent the sideways sway. You should also see a sideways lean going around corners.
Dec 31, 2009 | 2002 Jeep Grand Cherokee
What is the best fork for my MTB ? i
You havn't actually mentioned the bike, but anyway, get some advice on which size travel to purchase, and a good brands to go for would be , FOX, or Marzocchi, Rock Shox are way over rated
Oct 10, 2009 | RTO Rock Shox Mountain Bike Bikes Fork...
2001 town and country sways to much
You most likely need new struts and shocks. especially in the rear. It is common. If it feels like this all the time including driving straight, then check that sway bar an ends aren't broken.
Sep 13, 2009 | 2001 Chrysler Town & Country
My explorer's cab rocks back and forth
If you cab is rocking and/or swaying from slightly rough terrain, then it is time to service your shocks and springs. Over time both shocks and springs weaken, causing the vehicles own weight to compress them.
Feb 13, 2009 | 1999 Ford Explorer
Iron Horse Warrior Elite Logo
277 people viewed this question
Top Iron Horse Cycling Experts
Colin Stickland
Colin Stickland
Donald Ayers-Marsh
Christopher Smith
Are you an Iron Horse Cycling Expert? Answer questions, earn points and help others
