Question about Altec Lansing 121i Computer Speakers
Hi there My Altec Lansing 121i power transformer is spoilt. I would like to replace the same. What are the voltage ratings of the transformer Thanking you Vivek
  • 1,591 Answers
This is one of those "it's cheaper to replace the speakers" scenarios as these units can be had for $25 new, and for even less on E-Bay.
Posted on Mar 27, 2011
Power supply out put rating ? lost the original power adaptor that came with system acs340. trying to use a substitute
what is an acs340 ?
Is it a Altec Lansing subwoofer speaker for a computer
google search a4432 altec
13V 4A DC
If you decide to buy one check the input AC voltage matches your power outlet supply voltage 120Volt AC 60 hZ or
is it 240V 50
Hz - get it wrong and smoke may escape from the power adapter after the big blue flash occurs.
https://www.ebay.com/p/Genuine-OEM-Altec-Lansing-A4432-ACS340-Subwoofer-Power-Supply-13v-4a-AC-Adapter/664023647
Feb 11, 2018 | Power Computers & Internet
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Hello. I have the altec Lansing acs40speakers but no power supply. What voltage do these need?
Class 2 transformer
Model: 4815090r3ct
Input 120vAC
Output: 15 vDC, 900mA
Center is positive, outer is negative.
Dec 04, 2010 | Altec Lansing Multimedia Computer Speakers
No power in my altec lansing S100 121i 2.1 speakers
troubleshoot the transformer and try to replace the Opamp (UTC458) on the circuit board. the Opamp might be broken and shorting the circuit and fry your transformer. goodluck.
Jun 26, 2010 | Altec Lansing 121i Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Althec lansing 121i speakers not working
they might have problem the fuse..change this and and they working like a charm.
Feb 13, 2009 | Altec Lansing 121i Computer Speakers
Altec Lansing computer speakers , power requirements
You have to find out what the speakers are rated at then go form there. There is usually a placard or sticker on the back that says what watts and voltage they are rated at. Then you have to find out what plug goes in. Or you just buy an OEM plug
Dec 06, 2008 | Altec Lansing Multimedia Computer Speakers
Altec Lansing 121i Computer Speakers Logo
167 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
