I have inherited a hifisonic digital clock / date / alarm / temperature clock with no instructions ..... help please to set this for me,it's driving me crazy Many thanks
    Problem Solver:
  • 3 Answers
Buy another Brand with Instructions
Posted on Jul 04, 2012
Setting A Westclox 72020 Digital Alarm Clock with day, date, and temperature
Try Googling (Westclox)(72020)(manual) without parens for instructions.
Apr 10, 2018 | Westclox Audio Players & Recorders
Northwest Stars soothing Lullabies clock instructions
I have no + or - buttons. I only have:
Mode
set C or F
Alarm
Snooze
light
select
volume
sound on/off
Please help!
Thanks!
May 02, 2014 | Home
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
Setting up the Date & Clock after reset
Follow the instructions on the first page of this manual.
Apr 05, 2013 | Sharp EL-1197PIII Calculator
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jan 14, 2011 | ESQ 07301132 Aerodyne watch
I have a Kenko KK-613D LCD clock which came inside a bathroom cabinet, but no instructions, can you help please.
BP Digital Clock Instructions (translated from French)
Manual:
1. To set alarm in normal mode press M twice.
Press S and D to set then press M to exit.
2. ADJUSTING the Time and Date:
Press M three times to go to setup mode
Press S to go on setting the minutes and press D for adjustment
Press S again to adjust schedules and press D to set
Press S again to adjust the date and press D to set
Press S again to adjust the month and press D to set
Press S again to adjust the week and press D to set
Then press M to return to normal. The previous settings are automatically saved.
Press D to display the date.
Oct 29, 2010 | Watches
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 | Vacuums
Hi i have an alarm clock digital it is called an ascot by kripplwatches the serial number is... po5623 type .. hsd110b it is only a cheap thing but i like it and can not fiind instruction manual can you...
to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
to set the date: same prcedure as time but first switch to the date display
Jan 03, 2010 | Watches
Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Jun 30, 2008 | Audio Players & Recorders
353 people viewed this question
 Grubhead
Grubhead
